02 Monte Carlo rear suspension help
Not sure if any one can help but all info is greatly appreciated.
I have a 2002 Chevy Monte Carlo SS
i have my system installed with the 3 batteies and subs and enclosure installed it weighs prob at most 400 lbs more in trunk.
my question is what can i do to lift it back up to factory level as it sags from the wieght
i put rubber spacers in the coils but the only last few weeks until they split.. i have contacted monroe and midas places and tehy say they donot make any bigger coils i can replace even GM said
they dont make them bigger.
my coils are most likely original as i havent replaced them since ive had car for 3 yrs.. my quickest fix is to get new coils and shocks but i would like something stronger so they wont eventually sag again
thanks for any and all help
2007 Ford Ranger
(ALL YET TO BE INSTALLED - DUE TO WORK SCHEDULES)
K&N Performance Air Intake
Massive Audio D2400 Mono Amplifier
2 Custom Built 8" Subwoofers in Ported Enclosure
Pioneer AVH-P4400BH In Dash Double Din DVD Player (Video Bypassed)
4 - Pioneer TS-A6886R 6" X 8"
2 - SMD Heavy Duty Single ANL Fuse Blocks
2- Stinger SPP1200 Dry Cell Batteries
JL AUDIO Interconnects
2/0 Gauge Big 3
ILL Customz 8 Spot Flat Lug Style Bolt Down Terminals
ILL Customz 1/0 to 4 Gauge Power / Ground Reducers
Factory Alternator
__________________________________________________________________________________________________________________________________
2002 Cheverlot Monte Carlo SS - (Deceased)
2 - Rockford Fosgate Power 1501BD
1 - Rockford Fosgate Power 851x
Rockford Fosgate Power 6 1/2 Components
Rockford Fosgate Power 3 way 6x9
2 - JL Audio W7 13.5" Subwoofers (Sealed)
Pioneer AVH-P4400BH In - Dash DVD Player
Pioneer AVIC - U250 - Add-on GPS Navigation System
Audio Control 6XS 4 Way Crossover / Line Driver
Ohio Generator 200 Amp Alternator
3 - Stinger SPP1200 Batteries
1 - Optima D34/78 Battery
get the helper bags that go in between your springs or do an air ride. or get the weight forward of the rear wheels more.
THERE IS NO BUILD LOG!
1998 Chevy Silverado ext cab
Alpine CDA-9887
4 Team Fi 15s
2 Ampere Audio TFE 8.0
2 Ampere Audio 150.4
8 XS Power d3400
6 XS power d680
Stinger
Tsunami Wiring
Sky High
air shocks, it will ride more rigid than it does now, but will solve your problem for relatively cheap
1969 Chevy Chevelle
20/22" staggered Bonspeed Huntingtons wrapped in Nitto INVO's
Mechman 250amp cs144 alt w/AVBM
Kinetik 1800 main battery/Kinetik 2400 in the trunk
Pioneer AVH-3200dvd Headunit
(2) sets of Hybrid Audio Technologies Imagine components up front
(2) DD 3512's d4 coils
Sundown sax100.4 component amp
Sundown saz-3000d subwoofer amp
5ft^3 box tuned to 34hz
MY BUILD
this is what I used and got 1 1/2 inches higher with my Monte 500 lbs heaver rear springs
https://www.wbodystore.com/Rear-Heightening-Springs-p-304.html
I am running 2 15s and 2 extra battries in my Monte
here are some pics
http://s1178.photobucket.com/albums/x380/blazed-ss/
and if you ever need help with other parts hit be up on the montecarloforum.com same screen name
2001 Monte Carlo SS / HS
https://www.wbodysto...ings-p-304.html
here are some pics
http://s1178.photobu...x380/blazed-ss/
thank you very much i will be looking into asap
2007 Ford Ranger
2/0 Gauge Big 3
Factory Alternator
here are some pics
you bet man :OhYeah:
  • Who's Online   0 Members, 0 Anonymous, 1440 Guests (See full list)
