Pre fabs i would stay away from
why?
Because he said so....sheesh. But more importantly because they suck. You'll have a lot more pride in your build if you do the work yourself :)
I personally don't like gorilla glue because it expands when it drys, which gets everywhere. I use a product called PL Premium. I used it when I was a contractor and was amazed by what it could hold together. I lay about a 1/4-1/2" bead and when you screw the boards together, it squashes out. You can take a peice of scrap to scrape all the excess off and it seals your joints perfectly. If you are going to screw your box together, I personally use 1 5/8 coarse thread screws and I pilot drill every hole with a 3/32 drill bit. It does tend to split slightly, but if you go slow it won't.
Best of Luck and Cheers!
There is a point of diminishing returns on the amount of equipment installed, kinda like throwing money out a window.
  • Who's Online   0 Members, 0 Anonymous, 488 Guests (See full list)
