So.. how do u know how its tuned exactly? and how many / what size to put. Just wondering this because it seems these boxes are capable of a bit more.
Vehicle: 2002 Volvo S60 2.4t awd.
Headunit: Kenwood DDX-470
Doors: 4x Focal 6.5s/tweets (Adding)
Sub: 2x Sundown Zv4 12's D1
Amps: B2 Zero.1, MB Quart OA600.4
Box: 5.2ish @ 32, Made with Maple, solid oak braces, 45s all around, 2x 5.8" pipes, all fiberglassed up.
Battery: XS D3100, Block Shakers 110AH
Alternator: 250A Excessive Amperage.
All Sky High OFC Wiring.
My Build, plenty of pics: http://www.stevemeadedesigns.com/board/topic/198281-2002-volvo-s60-awd-24t-build-log/
download torres box calculator, put in the dimensions of your box than put in how many ports, how big, and the length to get the tuning you want
Pioneer deh-80prs2 10" Tantric Sounds HD's Ported Box Tuned to 33hzSoundqubed 3500.1Hertz HSK 165Tantric Sounds 6.5" Coaxials80sq ft of MurdermatXs Power D3400 & D3100
Sky High Car Audio Cable Throughout
[quote name=^_^ Gem132' timestamp='1315212041' post='1673854]
Yeah I got that, what if theyre flared tho?
and what do i put exactly.. # of ports say 2.
so do i fill out the height width and diameter?
and common port walls = 1
Edited by JMac91
bump..
no common wall is 0
if u put # of ports at 2 then ull need 2 ports
no you do not fill in hight width and diameter... you fill i the # of ports, diameter and leangth..
if you want tell me your Subs, Space, port diameter desired ( 4, 6 or, 8 ) and ill build you a box in sketch up and post you a vid on my you tube channel...
Edited by CutlassTakenDumps
