scooter99 Posted February 11, 2012 Author Report Posted February 11, 2012 First things first here's a little package I got earlier this week. These are the headphone amplifiers that are going to go in the back seat somewhere. Originally it was in the center console, but I'm rethinking that one at the moment. I'll get back to that. Here they are! Front, volume knob, power button, and 3.5 mm jack. Rear, has two sets of outputs for speakers, also a set of RCA jacks for the inputs. I'll have to make a 3.5mm to RCA cable. Side by Side This is a crappy pic, but it's dark outside and I just took it. This was my original idea, however, counter sunk at an angle in the arm rest. But, looking at it from this point of view, or at least where I was standing, I can see how it could create a problem with reaching them. Then I thought about this spot. There, as you can see, is a little outlet in the seat there, and they almost fit perfectly. The problem would be, how to attach them to the seat. Fiberglass pod, with them seated inside it, but how would I attach the pod to the seat. Then I got to thinking, even that might become an issue, although not a big one, because they would have to reach kind of far forward to reach the knob on them. I'll have to get the girls in their seats and buckled in to see which one is better. I also liked the thought of removing the cup holders and putting them in there, standing so the front of them was facing up. However, that poses a problem cause they're about an inch to an inch and a half too tall. So that may not work. I'll have to do some more researching on it to see what the best fit is. It's not a real important project right now. I have another project going on now. Let me get to that! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 11, 2012 Author Report Posted February 11, 2012 So here's where I'm at with the Alpine Face Plate Extension Project. I got the head unit out of the truck tonight and just started looking at stuff and getting some ideas on how to tackle this project. My oldest daughter was a little jealous, bless her heart cause her sister got to be on a picture in the build. So she wanted in on one as well! So I got everything laid out, all my pieces to this puzzle. Put the face plate on the unit and examined the contacts a little bit. Here is the close up on them. You can see on this one, that there is a little tab on either side of the contact connector. This is key cause the contacts really only go in one way smoothly. The other way it goes in, but it's kind of forced. So this is a good thing for orientation purposes! With this connector, you can see the top connectors extend down, and the bottom connectors aren't so extended. This is another helpful piece of info for orientation! This is just a view of back of the female connector and the top of the male connector. Showing them connected Same basic thing, just roles reversed this time. Connected This just shows how the connector will go into it's spot Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 11, 2012 Author Report Posted February 11, 2012 Both of the base plates. The top one is the new piece and then you see the connector in front. After looking a bit at it, I may change out the one on the unit cause it's a little worn. The one for the faceplate to be held on, doesn't need to do anything but hold the faceplate. The base unit one, needs to be moved if I need to put in a cd. Anyway, moving on. Now it's time to get our color chart and wires all situated so I have a guide to go off of. No reason to mess something up by guessing right. Now that I have that going on, lets take a look at the wires and colors I wrote down colors as I thought they should go. But then I discovered later that they had numbers on the wires. So I changed the color code later. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 11, 2012 Author Report Posted February 11, 2012 Here's what's in each cable. Remember there's 8 cables in the main run. So each pair per cable equals 16 little wires. There's 16 contacts on each plug. Make sense now! So after looking at the female connector I wondered what it looked like in the unit. So I decided to take the front off and look for myself. To my surprise this is what I found. I don't know exactly what I was expecting but I thought I'd have a ribbon cable or something in there. It's a board that has another plug on it, that plugs into a female plug that's soldered on the main board. WOW. This is how it's soldered to the board. So I started stripping, wire that is! One down, one to go Two down. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 11, 2012 Author Report Posted February 11, 2012 Next to strip the ends and get em ready for soldering or tinning whatever you wanna call it. Done and ready for solder. . That's as far as I got tonight. My eyes hurt, my head hurts, and it's time for bed. So I have to now solder the ends, solder the connectors, and then put them together. The connectors aren't very strong so this is a little intimidating. I wish I had a better solder tip, but I literally have no money in the bank right now, so i can go get one. But I think I have one that will work. I just don't want to ruin anything. I did find this out however. This is the picture from above, altered. What it's pointing at is a button. That button is pressed by the arm that goes down when the face plate opens up. I'm guessing it has something to do with the eject button. That's just a guess though. But if that button has to be depressed for the eject button to work, then I'm going to have no choice but to do a face plate of some sort on the base. I was planning on it really anyway. I'm probably just going to get the piece that goes on the front, then I'll have an empty face plate. But it'll look good still. So that's it for tonight. I'll see how much more I can get done this weekend. You're welcome to comment or view the behind the scenes chatter on my build log, which is linked in my signature. Thanks! Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 13, 2012 Author Report Posted February 13, 2012 Ok so last night I was able to fire up the soldering iron and get the head unit extension all finished up and working! Well, sort of! Here's how it went down! First I got everything out and started working on it, pretty much where I left off from last time. Recall that everything was stripped off and ready to solder on the wires. Now my original plan was to just solder from the outside in, meaning I was going to lay the wires on to the tabs and solder them on and then bend them and do the other side. After looking at them for a bit, I decided that these tabs were just not strong enough to really do that. I decided the up most care was needed in the soldering and handling of the connector tabs. So to solve that and get that result, I decided that the best thing to do, would be to bend the wires in an "L" shape and solder them that way, and then when they go on the tabs, they'll be resting on the strongest part of the tab, which is not the wing, but the body of each tab. So that's where I started. I needed to tin each little wire. 8 pairs, twice = 32 wires! Actually kind of went pretty quickly! Check it out! Before tinning Just to see the plan, if it'll work better! Time to solder Same here, pre tinning Now I started to solder the wires to the tabs. But I pulled these wires off. Rather than try to fight space all the way down, I'm blind already and I was wearing my glasses, but my head was killing me after looking at this stuff for a while in crappy light! So I tried to make it a little easier on myself by doing it from the bottom up instead of the top down. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 13, 2012 Author Report Posted February 13, 2012 It's a little rough right now. But I can clean that up! Now it's time to move on to the next connector. I actually found this one tougher than the first one. These tabs seemed thinner and more brittle than the other one. I decided to do the same thing with these. "L" shaped wire from the inside. Also from the bottom up. Again a little rough and then cleaned up! BTW, I don't claim to be the best solderer in the world, I'm still learning. So if anyone thinks they can give any suggestions as to how to better my solder joints, I"m all ears! Thanks! Moving on! Soldered up and ready for some support and connection. Got out the hot glue gun and started filling the wires up and this will help support the weight of the wires and prevent the soldered tabs and bare wires from touching. Side one Side two Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 13, 2012 Author Report Posted February 13, 2012 Now to move a little up the wires for more support. Once again, it's not the cleanest, which if you all know me by now is driving me nuts, but like I said a bit earlier my head was killing me, and I was getting impatient with these connectors. No excuse to let the details get away from me I know, but it's what I'm using for this now. Ready to put it in it's home. What you'd see if I took the face plate off. Looks factory! I compared it to the one from the factory, and it's the exact same distance, which is flush. I'm happy with it. Wires supporting themselves and the connector and base. Now, on to the next one! Same thing done here, I'll just post pics, you get the idea. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 13, 2012 Author Report Posted February 13, 2012 Not the greatest picture but here you can see I filled in the sides of this one. The other one I wasn't able to fill in on the sides because the tabs in the center need to move in order to take on this connector. I didn't want to take the chance that it would be glued. But this one doesn't have that issue. Got it on the face plate back, the false one. Now they're ready to go! Next I got out all the equipment and a battery and it was time to test her out! Remember this was the full length cable. 10 feet long. I had really no expectations for this one to work based on what I'd heard and read about extending these newer alpine faces. But my hopes were positive and it would be nice if it did work! Now the false face plate base won't just sit in there. It needs the front in order to stay on, because the front is where the holes are for the bottom in order for those pins to go into and the plate to stay in place. So I did the next best thing, which was electrical tape it. So now it's in place. The false base, is a different story. The face plate will stay on it cause it has those holes. Here it's in place and open. Just to show the contacts. Up and in place. Facebook Page: S99Creations 2006 F250 Lariat Build
scooter99 Posted February 13, 2012 Author Report Posted February 13, 2012 Power and ground hooked up, got a buzz from the unit loading up. We're powered! AAAANNNNNNNNNDDDDDD! NOTHING! Damn! So basically that pretty much eliminates the ability to put it in the headliner. I need at least 8 feet of cable to get it up there around the windshield. SO the headliner is out, and now it's the dash bezel under the tablet. But instead of just taking the option I HAD to make sure it was in fact going to work. It's like play golf, you have to hear the ball drop in the cup. Well here I had to see it work for myself. So I cut each one about 2' in length giving me 4' total. I figure this was plenty to work with. Now I didn't want to take the time to put crimp connectors on each one cause I wasn't going to leave them like this. I'll be making molex connectors for each end, and then making a harness cable in the end that way I can remove either end if i need to for whatever reason. However, for the bench testing, twisting and electrical tape will do. Round two ready................................................nothing! EFF!! At this point I was getting pissed. I figured 4 feet would work for sure. I can't imagine a run this short would not work. So I got out my DMM and checked each and every wire. I connected both plates together via electrical tape, and tested all the wires. Non touching, all connected correctly. NOW I'm stumped. But I couldn't stop so I did it again. Cut it down even more. I cut off 10" of the wire and reconnected. Tried it again! ITS ALIVE, ALLLLIIIIIIIVVVVVEEE!!!!! WOOHOO!! However, now I may have a problem. I'm sitting at 32" now. Even though the glove box is right next to the dash bezel, I have to go all the way to the front of the glove box, not just to the back end of it. So it may be too short to work with. I need to get in the glove box, figure out where it's going to sit, and then take a string and take a measurement so I know exactly how long I need this to be. I'm also going to keep adding inches until I don't get the face plate on anymore. I'm hoping to get another 4" - 6" out of it, but I have a feeling that I may only get 2". But at this point, I know where it has to go, which is below the tablet. That will allow me to move forward with the tablet install and know where it's all going. Until then, I'll keep adding inches until I can't go any further. So there you have it, my work for the weekend! Thanks for tuning in! As always, you're welcome to follow along with the behind the scenes chatter by checking into my build log which is located below in my signature! Facebook Page: S99Creations 2006 F250 Lariat Build
