nick23parker Posted September 8, 2011 Report Posted September 8, 2011 This weekend i plan on building my first ever sub enclosure for a single 12" sub woofer with an aero port. I have the port dimensions and box dimensions calculated i just was wondering if anyone had any tips on building the box or knew anything else i needed. My list so far: 3/4" MDF Board 1" Screws (What exact type? Anyone know for sure? Drywall?) Wood Glue Caulk Upholstery Tools: Drill Saw Measuring Tape Anything else? It's just going to be a square or rectangle so im starting easy. 2004 Toyota Tacoma Double Cab 1 Rockford Fosgate P3 12 inch subwoofer Custom built ported box fit to specs of subwoofer Rockford Fosgate P400.1 Amplifier Rockford Fosgate Power 5x7 and 6x8 door speakers Pioneer DEH-P4200UB Headunit
727Designs Posted September 8, 2011 Report Posted September 8, 2011 3/4" MDF 1 5/8" Coarse Thread Drywall Screws Titebond II Clear Silicone Whatever you want to cover it with. Tools: Drill Router (Not a necessity, but makes life easier) Jigsaw if you don't have a router Saw Measuring tape Straight edge (If you're not using a table saw it will save you ALOT of time and headache) Clamps Corner Clamps (BIG help) Remember to square up your sheet before you start, I NEVER trust a factory edge. After that be careful, measure twice cut once. ALWAYS predrill, avoid being 2" from the end to avoid splitting. I like to countersink my screws as well. Make sure all of your seams are smooth and go together good. If your cuts are good you won't need to seal it, I always just do a thin bead of clear silicone to be on the safe side. Good luck. -Zach-2010 Toyota TundraFull Hybrid Audio SQ 7" BDS on 37's 2000 Ford Expedition 160+ dB Green Turd -SOLD-
The Teen Audiophile Posted September 8, 2011 Report Posted September 8, 2011 This weekend i plan on building my first ever sub enclosure for a single 12" sub woofer with an aero port. I have the port dimensions and box dimensions calculated i just was wondering if anyone had any tips on building the box or knew anything else i needed. My list so far: 3/4" MDF Board 1" Screws (What exact type? Anyone know for sure? Drywall?) Wood Glue Caulk Upholstery Tools: Drill Saw Measuring Tape Anything else? It's just going to be a square or rectangle so im starting easy. Make sure you pre drill the holes before you start drilling in the screws ( Drywall works just fine ) and the diameter of the hole should be about 60% smaller then the screw diameter itself. Also, use good quality caulk, and run your finger along the edges when caulk is added to get a good seal.
Nine8SST Posted September 8, 2011 Report Posted September 8, 2011 And if it's youre first build, keep a couple bandaids nearby.......it never fails! Speaking from experience of course LOL! 1998 SS/T Ram Build Log - Kenwood KVT-514 and KNA-G510 Navigation - 2 DC Level 3 12" - Components??? - Sundown ??? - Sundown??? - Knu Konceptz - Second Skin Dampy Pro - XS D6500
nick23parker Posted September 8, 2011 Author Report Posted September 8, 2011 The hole for the aeroport how big should it be? 4 inch in diameter 10 inches long but im not sure the diameter hole should be 4 inches. Im using a table saw and my friend may have a router. i know the sub cutout is 11.25 not 12. lol. any tips on upholstery? i plan on a vinyl that matches my interior or should i go with a carpet? how do you get rid of the seams? 2004 Toyota Tacoma Double Cab 1 Rockford Fosgate P3 12 inch subwoofer Custom built ported box fit to specs of subwoofer Rockford Fosgate P400.1 Amplifier Rockford Fosgate Power 5x7 and 6x8 door speakers Pioneer DEH-P4200UB Headunit
