Need Help On Car Audio
Hey Guys,
Equipment:
Kenwood KDC-HD548U
Powering:
Nothing
Rockford Fosgate Punch Series 2 Channel (P500)
Powering:
(2) Alpine SWS-1223D Subs
Eclipse 325 Watt 2 Channel Amp (E325)
Powering:
(2) JL Audio TR400-CXi (Front 4in. speakers)
Everything is ran with 16 gauge wire. The sub box is ported. The power cable is split and divided.
I was wondering how i could add tweeters or more speakers into this system, thanks
If the amp is 2 ohm stable you could throw a pair of coax in the mix or more with proper wiring you could do 4 4ohm speakers per channel just wire them up series/parallel and it should give you a 4ohm load so you woud have a total of 8 mids/highs but will be under powered, but another amp+more speakers. Hope it helps bud
Kenwood KIV-BT900
Front Stage
RF 400-4 Runs off dedicated 4 awg ofc
RE 6.5 125.5.
Lanzar Max Pro 6.5
Boston S60 6.5 components
Rear
Soundstream BX-15
4x Sundown SA8 v1.5
Crescendo BC3500D
2.4 net 28hz
4 runs of 0 gauge
Big 3
HC2400
700ca up front
Singer 350 Amp Alt
No deadener :/
Scytek Galaxy Alarm
thanks dude
