any 1 use this amp b4 and what kind of real power do you guys think it outs out thanx
http://www.sonicelectronix.com/item_28221_Performance-Teknique-ICBM-CLASS-D.html
Power Specifications - Full Range Channels
RMS Power @ 4 ohms 650 watts x 1 channel
RMS Power @ 2 ohms 1100 watts x 1 channel
RMS Power @ 1 ohm 1500 watts x 1 channel
Bridged RMS Power N/A
Peak Power Output 3000 watts x 1 channel
Amplifier Specifications
Amplifier Class D
Number of Channels 1 - Mono
Total Peak Power Output 3000 watts
Total RMS Power Output 1500 watts
Maximum Input Gauge Size 4 AWG
Minimum Impedance Unbridged 1 ohms
Minimum Impedance Bridged Not Bridgeable ohms
THD at Rated RMS Power .02%
Speaker Level Inputs No
Preamp Outputs No
Built-in Crossover Low-pass (LP)
High-Pass Crossover Frequency N/A
Low-Pass Crossover Frequency 35 - 250 Hz
Subsonic Filter 15 Hz fixed
Signal-to-Noise Ratio >90 dB
Channel Separation N/A
Bass Boost 0 - 18 dB
Bass/Gain Remote Yes
Fan Cooled Yes
Fuse Rating 80A x 2
never seen it before but it has 2 80 fuses so it could put out around rated
*current*
1991 honda crx si
2 skar audio 12s
pioneer 6.5s
dual 400 watt amp
audio technix
db 1/0 wiring kit.
dual head unit
  • Who's Online   0 Members, 0 Anonymous, 3364 Guests (See full list)
