im confused about what to put in the trunk of my grand marquis i wanna do 2 15s but i also wanna do 4 12s if i were to go with the 15s id do the new aq hdc4's but for the 12s id go with the aa havocs they will be powered with the aq 2200 now the real question is which set up will slam the lows the hardest i have 10 cubes gross to work with but i can get proble 12-14 cubes if i have to
Edited by Hitman813
I'd say 4 12"s but, I wanna see those new HDC4's in a build log here. Hmmm decisions, decisions. :)
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
an hdc4 and a 2200? that thing will laugh at that power. measure your trunk out and we will see what you can fit REALISTICALLY in your trunk.
u must have never seen the trunk of a grand marquis before the 10 cubes i can get is before adding the shelf where the spare tire goes and i can also get more room above the tire wells if i had to guess i could get 16 cubes if i build in the trunk
Depends on if you want to build in the trunk or not. Doubt you could just set a 10cf box in the trunk through the opening. Also, I'm assuming you mean gross. Net is AFTER displacement.
yeah my bad ment gross ill fix it and yeah the 10 cube box will easly slide into the trunk i did the measurements and tried it with a cardboard box to make sure
Unless your sealing it off its pretty impracticle to take up all your trunk room which I'm assuming your sealing it off. And if your not sealing it off you will just have a loud trunk.
Edited by bassrace
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
lets see there supposed to be rated at 2500 rms they have yet to actually post anything about the sub saying its rated at 2500rms or more so im pretty sure a aq2200 at 1ohm at 14volt would be plenty enough to feed that subs hunger please do some research before u jump on someone thread and opening ur mouth thank you
do some research? bro ive been on here for almost 5 years. and maybe YOU should look up videos of the hdc4 before you rage on me.
http://www.youtube.com/watch?v=dcSRsVwTjp0
try reading the description.
see thats the problem the only way id actualy be able to seal it off is to put 4 10s in it cause the way the trunk is shaped theres the main trunk area then theres a shelf thats 12in tall and 3.5 feet wide so sealing it off isnt an option
