bassrace Posted September 11, 2011 Report Share Posted September 11, 2011 (edited) An hdc3 will like a 2200. I'm pretty sure its rated at 2000rms.(the hdc4) But a 3500 per hdc4 is more praticle. But hey its your setup do what you want/need it does'nt matter what anyone else says. Ya dig? Edited September 11, 2011 by bassrace Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
bassrace Posted September 11, 2011 Report Share Posted September 11, 2011 Unless your sealing it off its pretty impracticle to take up all your trunk room which I'm assuming your sealing it off. And if your not sealing it off you will just have a loud trunk. see thats the problem the only way id actualy be able to seal it off is to put 4 10s in it cause the way the trunk is shaped theres the main trunk area then theres a shelf thats 12in tall and 3.5 feet wide so sealing it off isnt an option I'd go 4 10"s sealed off then imo Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Hitman813 Posted September 11, 2011 Author Report Share Posted September 11, 2011 an hdc4 and a 2200? that thing will laugh at that power. measure your trunk out and we will see what you can fit REALISTICALLY in your trunk. lets see there supposed to be rated at 2500 rms they have yet to actually post anything about the sub saying its rated at 2500rms or more so im pretty sure a aq2200 at 1ohm at 14volt would be plenty enough to feed that subs hunger please do some research before u jump on someone thread and opening ur mouth thank you do some research? bro ive been on here for almost 5 years. and maybe YOU should look up videos of the hdc4 before you rage on me. http://www.youtube.com/watch?v=dcSRsVwTjp0 try reading the description. ive seen the video and ive read the description and ive also messaged that guy about his testing he said when he tested it it did 8k burb at 3 min and 10k at 30 seconds dont come at me with stuff ive already did research on im not gonna sit there and throw 5k on a sub and only have it be able to play for 15 20 min or even throw 3500 wats and have it only do good for an hour i do alot of driving back and forth from work most of the time 1.5-2 and sometimes 3+ hours away and i wanna be slamming the hole time Quote Link to comment Share on other sites More sharing options...
bigaltexas Posted September 11, 2011 Report Share Posted September 11, 2011 id go with the 15's.. might wanna get a aq3500 though.. Quote Link to comment Share on other sites More sharing options...
Hitman813 Posted September 11, 2011 Author Report Share Posted September 11, 2011 Unless your sealing it off its pretty impracticle to take up all your trunk room which I'm assuming your sealing it off. And if your not sealing it off you will just have a loud trunk. see thats the problem the only way id actualy be able to seal it off is to put 4 10s in it cause the way the trunk is shaped theres the main trunk area then theres a shelf thats 12in tall and 3.5 feet wide so sealing it off isnt an option I'd go 4 10"s sealed off then imo if i sealed it off id have to take off the back part of the back seat just to do it cause it doesnt fold down and if i were to take any part of the seat out id end up taking the hole seat out and wanting to wall it off and throw major power on it but thats not posable cause theres only room for 2 alts in my engine bay thats y im in this major confusion about what to do with this car Quote Link to comment Share on other sites More sharing options...
bassrace Posted September 11, 2011 Report Share Posted September 11, 2011 Go with the 15"s then, it's what I'd do an on top of that they're HDC4's. Quote 145.9@40hz 145.3@34hz big 3 X2 group 34 Deka Group 31 All 0/1 awg jl meta wire Alpine CDA 7894 Orion HCCA D5000 2 AQ HDC312's Crunch gpv1100.2 (for 6.5"s only) AQ pro audio 6.5" - 3 sets AQ supertweeters - 2 sets 2000 Slamry Link to comment Share on other sites More sharing options...
Hitman813 Posted September 11, 2011 Author Report Share Posted September 11, 2011 id go with the 15's.. might wanna get a aq3500 though.. not an option cause that would be 7k+ rms and i dont have the space for more than 2 batteries Quote Link to comment Share on other sites More sharing options...
Hitman813 Posted September 11, 2011 Author Report Share Posted September 11, 2011 Go with the 15"s then, it's what I'd do an on top of that they're HDC4's. ohh believe me i wanna get them so bad just cause there new but i dont know a hole lot about them yet cause what ever i get is gonna be tunes to about 26 or 28 herts and idk how those subs would handle that Quote Link to comment Share on other sites More sharing options...
Guest Posted September 11, 2011 Report Share Posted September 11, 2011 Go with the 15"s then, it's what I'd do an on top of that they're HDC4's. ohh believe me i wanna get them so bad just cause there new but i dont know a hole lot about them yet cause what ever i get is gonna be tunes to about 26 or 28 herts and idk how those subs would handle that why tune that low with aq woofers? if the 4 is anything like the 2.5 and 3's, then it will more than likely need a mid-30's tuning. Quote Link to comment Share on other sites More sharing options...
Hitman813 Posted September 11, 2011 Author Report Share Posted September 11, 2011 (edited) Go with the 15"s then, it's what I'd do an on top of that they're HDC4's. ohh believe me i wanna get them so bad just cause there new but i dont know a hole lot about them yet cause what ever i get is gonna be tunes to about 26 or 28 herts and idk how those subs would handle that why tune that low with aq woofers? if the 4 is anything like the 2.5 and 3's, then it will more than likely need a mid-30's tuning. cause i have a buddy that just built a box tuned to 28 and man i just love the way low tuned boxes sound edit* and i wasnt trying to sound like an asshole eirler i was just dealing with annoying people all day sorry about that btw Edited September 11, 2011 by Hitman813 Quote Link to comment Share on other sites More sharing options...
