I found a damn good paying job.
I want to have this built by the time spring rolls around:
1 ScyTek Vision Guard 8000 VS8000
1 10CF box tuned to 30Hz
1 200A HO alt
1 Pioneer 880 with USB input cable
1 Focal 165 V3E
2 Loaded 18" Fi BTLs
2 BXi 2607Ds
2 Kenetik 1400's
4 runs of positive 0 gauge
4 runs of negative 0 gauge
and a whole bunch of deadener
anything seem out of place?
Edited by Ku-sama
225HP 1996 S-Dime
JVC KD-G820
Crunch PZi 2250 powering Two Ascendant Audio Assassin 8s wired to 2 ohm at 225W RMS 2.26CF @ 36.4Hz 43.5 square inches of port with 45's
Kicker ZX350.4 powering CDT CL-61A's with TW-24 Tweeters
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
MSN: [email protected]
1 8.5CF box tuned to 30Hz
1 new HO Alt to run dual alts
1 set of Rainbow Comps, not sure yet
2 18" Fi BTLs
2 BXi 2607Ds
2 Kenetik 1600's
sounds tasty, you really dont need the dual alts.. if you want a bracket made for down the road when you wanna slew in a 2nd when you upgrade power than yeah.. but for what ur sayin its not necessary.. one beef'd alt should do the trick
- Infiniti QX4 - - 2 Digital Designs 9917s - - Digital Designs Z1 - - Digital Designs C3b -
well since I'd be buying a HO alt then I mind as well use the one I have right now too just because... it's still a powerful alt so it can't hurt, right?
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
bump?
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
the "I finally got a job so I can finally buy some good ish" bump
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
anything I should change?
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
i like ur thinkin on this one, a real system worth some real money
the only thing i can think to change is the amps
if ur goin all out like this then why not just go wit rockford??
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
Guest Nismofreak
those amps are the newest series from hifonics...you need a external fusing for it...It puts out the power that it says and even more or just get the Goliath from hifonics. It cheap as hell on ebay. You will be happy with those amps
Edited by Nismofreak
the distribution blocks I have have ANL fuses, would that work?
and I'm not really going "all out" I'll still be running the Kicker 350.4 for my components. and the BXI amps will be plenty loud for right now.
Edited by Ku-sama
225HP 1996 S-Dime
JVC KD-G820
Contact me:
AIM: Necromancer Ku
YIM: Ku_Karukasa
Guest Nismofreak
i think it should work. It will say the fuse rating in the instruction booklet.
