2 T2D215s
LilTeddyP
Right now I have roughly this, and I say roughly because when lowes cut my wood, they fucked up so this is now I remeasured what I have vs what I am supposed to have and came up with this. The port may be a little longer or shorter than what I have calculated as a result.
This is what I am thinking about doing.
The sound I am getting now is just too muddy, it's loud, just...I'm just not happy and I want it to be louder. Also with the subs up port back config right now, it is killing my hatch so subs up port up would be a better option for me.
I am currently running 1 T2500-1bd @ 2 ohms and with the new box I am going to want to run my other T2500-1bd so they will each be master/slave @ 4 ohms each.
All suggestions are welcome, I am on limited time to get something done because there is a show coming up on Sept. 25th in Lansing that I am "hosting" a "db drag" (not sanctioned, I will be using an SPL-LAB but it's better than the by ear bullshit they were gonna do, and it will be consistent because all cars involved will be using the same sensor)
Here is a flyer for the show if anyone in the area wants to come!
2001 Bravada (2wd) Pewter on 24's
JVC KW-AV60BT
10 Alpine Type-S 6.5s
2 PSI/BTL 18's @ 32Hz
2 Rockford Fosgate T25001-bd's @ 1-ohm each
Rockford Fosgate T1000-4
Rockford Fosgate T400-4
Rockford 3Sixty.2
Yellow top up front, 2 9a31s in the back
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
i didnt see the video or read anything but...cool story
and the reason your being a cock tonight is?
The box and port are just too small. You need more overall volume to get louder while still retaining a good all-around sound. Aim for 7ft^3 after displacements with 90-110in^2 of port...if you can fit it.
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
The T2's like a common chamber, roughly 6-6.5 ft^3 tuned to 35hz 13-15 in of port area per cubic ft would be nice....
Personally, I would do (1) 5ft^3 tuned to 33-35hz
Also 1 amp per woofer would be overkill, if your gonna run em, just run both off the
(1)2500 bdcp....cause s trapping them is Gina give you 5k at 2 ohm
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
Wont be strapping, will be master/slaving which to my understanding will only give each woofer power from each amp at its respective ohm load i.e. if each amp does 1300 @ 4 ohm, then that is what each woofer will see, correct me if im wrong on the master/slave
It is an og bd not a bdCP FWIW and I'm doing both amps more for eye candy than anything, not really looking for a gain.
Talked to Forrest @ Rockford today and we came up with 18x38.5x23 w/ 80in2 of port 27" long subs up port up to give me 33Hz Overall would be 18.75tall with the extra baffle
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
Thinking something like this Ryan?
Will be a little less internal after bracing
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
Looks good now man and Forest is a good dude to deal with over there he wouldn't steer you wrong.
Forgive me but which one do you think looks good? Forrests idea or the one I did to see what Ryan thought?
JVC KW-AV60BT
Rockford 3Sixty.2
LOTS of AT 1/0
Python 991
350 Amp Singer Alt
"Build Log"
My Facebook
My YouTube
  • Who's Online   0 Members, 0 Anonymous, 672 Guests (See full list)
