I wont bore ya with alot of typing, will go right into pics..
Here is some shots of the supplies.
Should have been one in there of all the other stuff.. Oh well "F" it.. Here are some decom pic's..
Head Unit: Alpine CDA 9887
Sub Amps: 4 RF2500's
Subs: 8 SA-12's Walled
Comp Amp: 1 RF600.2 (for now)
Comps: (4) 6.5 Punch Mid Pros and 2 Punch Pro Tweeters
Batteries: (1) XS D5100 (5) D3100
Power Cables: 2 runs of 2/0 power and ground each front to back(Try-Star)
Alternator: Dual Mechman Rhino 250's
Deadener: Fatmat / Damplifier Pro
Started with the floor and built from there.
I went a different path then most do, or at least i havent seen this kind of build be built this way.
So with the bottoms layed out and the an basic idea on the over all width and space i had i started to build each chamber..
Time for some test fitting..
Yup the back fits also..
SO i guess we can move on to baffels.
Had to stack them out side and see how they looked on a nice sunny day...I must syat they look awesome..
Started to do some glassing on teh inside and add some bracing..
Went ahead and wired up the boxes befor putting them in since it would be a tight fit..
Now it is time to place the boxes in the HOE..... :clapping:
dude... fuckin sweet. i was wondering where you have been lately
-Matt
2005 Dodge Magnum RT
JVC KD-AVX1
2 PPI S580.2
PRV 8MB450s
Audio Legion 3500.1D
2 RE MT 18s
360 ah LiFePO4 Battery
SHCA 2/0
155.2 @ 29 hz
Kicker CVR 15's build
DD 3512e build
Mini T-Line Build
(6) 8s Build
Nightshade 15s Wall Build
Magnum AB XFL 12s Build
Newest Magnum Build
