Unless you plan on going with more power, i'd stick with XLs. The XLs will take that power and then some and you wont have to worry about pushing them to thermal or mechanical limit. Im only doing 3 18" lvl 5s and plan on using 2 9ks if not some SD or stetsoms. Also, with that space, you've probably got the room for 4 18s...problem is going to be your height. 2 18s on top of eachother take up alot of space, so hopefully you've got almost 40" of height or you may be in trouble and may need to clamshell.
With 4 XL 18s, id shoot for 25ish cubes and I hear the XLs like alot of port, so shoot for 17-19 per cube. That port takes up so many cubes so damn fast. :cray:
Well, I do have over 40" of height, so that part should be fine. What about doing a fourth order, I just wonder if I have room for that? Or if it would be more efficient w/ the room I have?
I guess I really don't fully understand a 4th order bandpass yet?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
