Okay guys, I am planning my next build for my PT, and I need opinions. I am thinking about trying 4 18's, non-walled, no back seat. Since I'm still a rookie w/ the "bigger setups", I was kinda thinking about doing a box similar to Steve's, subs up port back, except since my car is smaller it w/ become a two seater. And the equipment I am leaning towards is DC. I was thinking 4 - level4 18's on a 5K for starters, with a 270a mechman alt, MLA VBM, and four XS D3100's, with two Kinetik HC1400's up front. Later I could still add a second alt, more batts, and a second DC 5K.
So my question is, does this sound like a good idea for me and my car? I am looking for a daily 150+ that sounds good on music and does a good ass hair-trick w ease. So is this gonna be a good idea? Would 15's be better considering my space? And wall/no wall??? I am open to all serious suggestions. And thank you for your time :drinks:
Edited by Purplehaze
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
4th Order wall 4 - 15's
on a DC 5.0K 2 DC 5.0K's
Solo X 15 (v.2) Sub Build
it doesn't make sense. Why not run 5 xs3100's
and 3 d3100 with 270a should be plenty for dc 5k.
Edited by LoudBimmer
Oh and in case you aren't familiar with my car, it's a 2002 PT Cruiser. Dimensions I have are roughly 41"W X 47"L X 27"H(up to the window line). That is with plastic in, could be more room made if needed. Here are some pics of it empty
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
True, only reason for the use of the Kinetik's is that I already own them. Just thought they'd be good enough together for up front?
But yeah guess I should sell them and put and XS up front too. So you think three w/ be enough?
Kickin' Cruiser
Seller Feedback
Stage 3
Dash, Door Panels,
id do no wall with the 15s to make sure you proper air space. that much cone area on 5k should do hair tricks with ease :)
www.dcsoundlab.comDCforum.jpgyoutube video's kbsmoker2011 MECAOH AS3 Champ 147.5OH DB2 Champ 125.9WF AS3 3rd 147.3WF DB3 2nd 128.3
SystemPioneer AVH-P4300DVD2 sets Fusion Encounter 6.5 componentson Crunch Ground Pounder 1200.418" DC NEO
on DC 5.0KKnukonceptz 1/0 through outBig 3 all 1/0XS D6500under hood D3100 in the backMechman 270....rebuilt by Ohio Generator :)
Do 15s but do xls do 1.4 coils and strapp 2 5ks down low. That's my plan in the near future
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 686 Guests (See full list)
