eltortuga94 Posted September 18, 2011 Report Posted September 18, 2011 If you have a dual 2 ohm sub and an amp that runs down to 2 ohms could you put the + & - of coil one into the left channel of the amp and put the + & - of coil 2 into the right channel so you could run & 2 ohms or would you have to wire in series at 4 ohms? System: Basically Stock In process of upgrading
MrSkippyJ Posted September 18, 2011 Report Posted September 18, 2011 run it in series. 2 ohm stereo is essentially the same thing as 4 ohm bridged (on the same amp) and you don't have to worry about matching the outputs. Edit: I am assuming you mean run it 2 ohms stereo vs. 4 ohms bridged anyway. My assumption is you are talking about a 2 channel amp (or 2 channels of a 4 channel amp) F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
eltortuga94 Posted September 18, 2011 Author Report Posted September 18, 2011 run it in series. 2 ohm stereo is essentially the same thing as 4 ohm bridged (on the same amp) and you don't have to worry about matching the outputs. Edit: I am assuming you mean run it 2 ohms stereo vs. 4 ohms bridged anyway. My assumption is you are talking about a 2 channel amp (or 2 channels of a 4 channel amp) Thanks. Yea, it's a 2 channel. System: Basically Stock In process of upgrading
MrSkippyJ Posted September 18, 2011 Report Posted September 18, 2011 and it's late, i'm dumb...you wouldn't have to match the outputs anyway, it's only one gain knob But still no real difference between 2 ohm stereo and 4 ohm bridged. You would want to run a mono input regardless. F150: Stock 2019 Harley Road Glide: Amp: TM400Xad - 4 channel 400 watt Processor: DSR1 Fairing (Front) 6.5s -MMats PA601cx Lid (Rear) 6x9s - TMS69
