ryanthebasshead Posted September 18, 2011 Report Posted September 18, 2011 hey guys im having trouble choosing the right DC sub. ive been getting different opinions from different people just wanted to post and see if i could get some help. as of now i have a honda prelude shuriken at35, big 3,1/0 throughout the car and an audioque 2200 .. i eventually want to upgrade amps which is why im still considering the xl so my questions are 1) which sub would be best for my amp 2) can my amp still work on the xl (even if obvously i need more power) 3) the xl thats for sale locally is dual one ohm so would it be ok? bad? to run my amp at .5 ohms or search for a d2? 4)i was planning on selling my shuriken to a friend and getting a kinetik 2400 is that too much for this? my alternator? any help would be great thanks, ryan
RickyFriery97 Posted September 18, 2011 Report Posted September 18, 2011 XL 18" is a good match for your amp, run at 1 ohm 2014 Chevy Silverado Crewcab 1994 Chevy Full Size blazer
ryanthebasshead Posted September 18, 2011 Author Report Posted September 18, 2011 hmm ok so i needa find a dual 2 ohm ..what about the battery? 2400 be fine or should i get like an 1800
AA98hoe Posted September 18, 2011 Report Posted September 18, 2011 Get the xl then later get another one if you want and another 2200 go with xs d3100 a lot better than kinetik and yes get a ho alternator stay with dual 1 and wire at.5 then like I said if you want more bass get another d1 and then another amp TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
ryanthebasshead Posted September 18, 2011 Author Report Posted September 18, 2011 Get the xl then later get another one if you want and another 2200 go with xs d3100 a lot better than kinetik and yes get a ho alternator stay with dual 1 and wire at.5 then like I said if you want more bass get another d1 and then another amp yeah idk about two of those ha but its ok to run my 1 ohm stable amp at .5? just feel d2 wold be better so i can wire it to 1 ohm and the xs d3100 is nice but pretty expensive i was gonna get the kinetik 2400 for $125
