georgiaspl Posted September 19, 2011 Report Posted September 19, 2011 Okay 1st off, none of my audio equipment is in my car yet b/c i haven't bought any new subs yet (still saving money). Im going to be running 5 amplifiers, 1 Memphis 4.125, and 4 Memphis 1.2500. I have a dual alternators already, both are 300 amp. One is running my car and is going to run my 4 channel. The other has a voltage module to run 18 volts, also I have 5 kinetik HC 16v's. Now is my 300 amp alternator and 5 batteries enough for my 4 1.2500s? or should I buy 1 or 2 more? Thanks
Watch the bass Posted September 19, 2011 Report Posted September 19, 2011 Sounds more that you need a thrid alt for your 2500 bank. "in the abundance of water, the fool is thirsty" Bob Marley
georgiaspl Posted September 19, 2011 Author Report Posted September 19, 2011 Sounds more that you need a thrid alt for your 2500 bank. 3rd alt? why?
georgiaspl Posted September 19, 2011 Author Report Posted September 19, 2011 what subs you runnin? haven't decided yet..it's between 2 sundown nighshade 18s or 2 smd 18s.
Watch the bass Posted September 19, 2011 Report Posted September 19, 2011 Sounds more that you need a thrid alt for your 2500 bank. 3rd alt? why? 10 K watts round 900 amp. "in the abundance of water, the fool is thirsty" Bob Marley
Sanitarium Posted September 19, 2011 Report Posted September 19, 2011 I don't see a point in running a 300 amp alt for your 14 volt stuff with just a 4 channel. Get a triple alt setup and run a stock work for that.
georgiaspl Posted September 19, 2011 Author Report Posted September 19, 2011 I don't see a point in running a 300 amp alt for your 14 volt stuff with just a 4 channel. Get a triple alt setup and run a stock work for that. My other 300 amp alt doesn't have the wire to connect to the voltage module..
