Box Tuned To 23hz?
Menace89
Both RE L-port calculator and carstereo.com says that my box needs to have 1.783 cu. ft. and be tuned to 22.76Hz (I figured doing 23Hz wouldn't hurt)
Will a box tuned to 23Hz would even sound good?
If anyone want to check it to make sure I got it right, I have 2 12" Cerwin Vega V-Max subs(but im doing separate box and port for each) specs on subs are:
Fs-28Hz
Qts-0.48
Qms-4.3
Qes-0.54
Vas-0.977 cu. ft.
Xmax-17mm
Cone area-70.8 sq. in.
I already have the box designed and everything, I just wanna make sure a box will sound good tuned to 23Hz before I build it.
Manual says 1 cu. ft tuned to 37Hz and the web site says 2.5 cu ft. tuned to 35Hz but with ony 20 sq in of port. so i dunno what I wanna do cuz 20 sq in of port sounds small
I think you would have a pretty flat response, but you would lose shit tons of output.
My System:
Pioneer AVH-P3200BT
4-Dayton 7 inch reference series (front doors)
8-Onkyo 3/4 inch tweeters (dash)
1-Sundown Audio 100.4D (mids/highs)
2-18" BTL's (for now)
Crescendo 3kwp (for sale)
Complete rebuild coming soon...
Guest Dylan Dude
that's what I was thinking too.
So then should I use the 20 sq in port on a 2.5 cu ft. box or should I use around 30 sq in?
I would download WINisd and spend a little time modeling up your subs and figure out which would work best considering what you are llooking for the subs to do. 30sq in of ports does seem a little small, but then again I have never used those subs. either way I would ditch the 23Hz idea. 30 is about as low as I would think of going for a sub box in a car.
My System:
Pioneer AVH-P3200BT
I downloaded WINisd and it says I need a 1.734 cu ft box tuned to 23.44Hz lol
Oh well, I guess Ill do a box tuned to around 35 Hz
Thx 01xtreme
  • Who's Online   0 Members, 0 Anonymous, 1934 Guests (See full list)
