TRTC360 Posted September 21, 2011 Report Posted September 21, 2011 So i've been in a hurry trying to find the proper design for my box for 2 skar audio VVX 12's (1993 transam) but I had no luck, my dad went ahead and bought a pre-fab without telling me, I got home from school and to my surprise the box was in the car. I hooked my subs up to my hfi 100.4, one channel per sub wires in series and to my surprise this box gets fairly loud with the higher bass notes, it doesn't kill the lows like a custom box would but i'm happy with it for now, I do plan on building a much better box for my car with lots of port area if possible. The issue i'm having is port noise on the lower frequency songs, is there anything I can do to temporarily fix the port noise? that's the box, it gets loud on just about 60rms per sub, for slamfest I will be running about 2400rms for competition and about 1700rms for demos so it should be quite impressive for just 2 12's, we'll see what happens though edit: the box is supposedly tuned to 36hz and it's about 1.35 cubic feet per chamber after all displacements, I tried inverting the subs but my hatch hits the motor , yes I know, prefab isn't the way to go but i'll be building my own box eventually. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
AA98hoe Posted September 21, 2011 Report Posted September 21, 2011 Is there a divideing wall between those ports ? If not put a aero tube there. They are way to small TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
FroznBeavrBALLs Posted September 21, 2011 Report Posted September 21, 2011 round the outside edges of the port. should do the trick. 2 DC 12" lvl 4s 1 DC 1.2k XS Power S3400 big 3 Alll KNU wire Pioneer HU cheapo Legacy coaxes (just for now) http://www.stevemead...n-sentra-build/
TRTC360 Posted September 21, 2011 Author Report Posted September 21, 2011 Is there a divideing wall between those ports ? If not put a aero tube there. They are way to small yeah it's seperate chambered, do you think I could possibly replace the top piece of the box and remove the dividing wall and run just one 4" or 6" aero port about 12" deep into the box? '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
tonedeaf Posted September 21, 2011 Report Posted September 21, 2011 Frozn..no...WAY too small port and probably tuned to 45.
AA98hoe Posted September 21, 2011 Report Posted September 21, 2011 Is there a divideing wall between those ports ? If not put a aero tube there. They are way to small yeah it's seperate chambered, do you think I could possibly replace the top piece of the box and remove the dividing wall and run just one 4" or 6" aero port about 12" deep into the box? That's what I would do. I would say lenghthen and widen existing but I m not sure if you can. Depending on the angles and depth of the sides TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
TRTC360 Posted September 21, 2011 Author Report Posted September 21, 2011 Is there a divideing wall between those ports ? If not put a aero tube there. They are way to small yeah it's seperate chambered, do you think I could possibly replace the top piece of the box and remove the dividing wall and run just one 4" or 6" aero port about 12" deep into the box? That's what I would do. I would say lenghthen and widen existing but I m not sure if you can. Depending on the angles and depth of the sides yeah there's not enough space to use the original ports and just modify them, if I were to modify this box I'm thinking about doing what you said just removing the dividing wall and existing ports, change the top piece, and run one aero port, i'm not sure as to wat size aero to use and how deep it should go into the box though. '93 Firebird Formula V8 H/U- Kenwood eXcelon KDC-X395 Mids/Highs Amp- Hifonics ZXI80.4 Wiring-KNU RCA's, Speaker Wire, And Two Runs Of Trystar 1/0 G34 Red Top and a 180amp Ford Alternator www.youtube.com/TRTC360
AA98hoe Posted September 21, 2011 Report Posted September 21, 2011 Try a 6 aero port from parts express and mount it in and out of box so you can keep tuning low then cut it down a inch at a time till you like what you hear TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
