coustic MX-3 crossover
TheEpicenter something? can find model number
rodek RA220
rodek RA230E
rodek RA250E
i googled the rodek amps and everything that comes up is german
might throw these in my little sisters car when she gets her lisence
thanks :drinks:
Low N' Slow
The epicenter is good stuff... :)
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
what exactly is it...? lol n00by question :noob:
I'm not the best person to answer that question because I wont be 100% accurate but I'll try :)
It can help boost frequencies that you normally wont get from my understanding i'm sure it does more, someone with more knowledge on this subject should chime in.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Here is the only things I could find out about what u have hope it helps
coustic XM-3 crossover
Specs:
Input current 0.5 amps max
Distortion 0.01% THD @1V
Freq. Resp. 10-30K Hz +/- 3dB
S/N Ratio >95dB (A-weighted)
X/O freq's (cont. var.)
Front HP (x1) 32-400Hz
(x20) 64-8K Hz
Rear HP 32-400Hz
Sub 32-400Hz
X/O Slope rate
Low Pass 18 dB/oct. (3rd order Butterworth)
High Pass 12 dB/oct. (2nd order Butterworth)
Sub boost 12 dB single oct. @ 45Hz
Input imp. 20K Ohms
Output imp. 100 Ohms
Output gain 1:2 (+6 dB)
Output voltage lvl 5V max
Dimensions 5"W x 6-5/8"L x 1-3/4"H
rodek ra220
1 × 17 Watt channel 1 an 4 Ohm
2 × 16 Watt channel 1 + 2 an 4 Ohm
rodek RA230E
30x2 @ 4 ohm
rodek RA250e
Specs are:
50x2@4ohm
90x2@2ohm
180x1@4ohm bridged
Hi SMD Members If anybody has computer problems and is an SMD member with at least 150 posts I will fix your problems for free by phone support or I can also fix your computer over the internet.... I have references such as All State insurance, Nationwide Insurance and much more... just p.m me for help.. I am not the greatest with when it comes to audio systems so I figured I could contribute to the forum this way.... Thanks David
thanks for the replies, how about the rodek amps? it was all hooked up to some oldie MTX blue thunder 12s. honestly it was decently loud for how old it is.
just posted what I could find in the above post
sorry bro u musta posted those specs when i was relying lol didnt see them, thanks tho man
seems like REALLY low power for how well it sounded
i was expecting alot more
Low N' Slow
  • 10 years later...
  • Who's Online   0 Members, 0 Anonymous, 1463 Guests (See full list)
