Reg_Cab_Slammer Posted September 24, 2011 Report Posted September 24, 2011 Box is going in a regular cab and i want it supa loud! hahahaha I can work out the length width and height stuff if you guys can help me with volume and what i should port to,but even though i want it loud i still want it clear. Thanks! Colby 2001 Dodge Ram Kenwood Deck Pioneer speakers
THiSiSTiNY Posted September 24, 2011 Report Posted September 24, 2011 I have my pair of type arghhhh tens 3ft^3 @ 35hz. Gets plenty loud and sounds good too. It's in a Tahoe though. Not sure if you will have space for that. But good luck with your build!
Reg_Cab_Slammer Posted September 24, 2011 Author Report Posted September 24, 2011 thanks man, im planning on running my 12 at like 2.5 or something tuned at 33-35 herts maybe 31 or so but ya ill try to post pics,itwill be a while but im tryna go ahead and get prepared 2001 Dodge Ram Kenwood Deck Pioneer speakers
98crewcab Posted September 24, 2011 Report Posted September 24, 2011 found for myself.....this means that I personally like it, nothing against what others are doing....2.3 cubes per sub, 30 sq inches of port per sub, tuned to 34hz.......had 4 in a blowthrough....loved it:) 06 2500hd, 6.0L, 4l80e, 4wd, (muah work truck) 7" BDS HC lift kit (5) 37x13.5R18 Toyo Open Country M/Ts (5) 18x10 Moto Metal MO962 tablet in lieu of deck blue tooth interconnect to soundstream eq (for volume control and bass control) 4 Alpine type r 10's 6 cubes net, 80sqin's port, tuned to 33hz 2 brutus brx5000.5's 2 pairs 3" polk audio for a pillars 4 pairs polk audio 6.5 comps 1 pair 8" polk audio for mids 2 xspower d3400 batteries.....learning alot from meade and his circle of some of the baddest installers ive seen- thanks guys, for not being so cocky and posting the way it should be done!P.S. Thanks Steve....for the demo!!!! loud as fauk!
pa-pa-platypus Posted September 24, 2011 Report Posted September 24, 2011 ive also had the best luck in my truck either port up on passenger side or towards the side wall passenger side..both have seems to work well for me with my 10's This isn't teeball. YOU DO NOT GET A TROPHY JUST BECAUSE YOU SHOW UP. Put the work in and then maybe get the respect when it has been earned 151.6 with single 12 at 41 hz 153.2 with 2 12's at 43 hz power: dd m4
Reg_Cab_Slammer Posted September 24, 2011 Author Report Posted September 24, 2011 I calculated everything last night and here are the specs 14" between seats (wide) 25" from back of cab to stick (its a standard) 15" tall port is 2"(tall) 13"(wide) 14.75"(long)= 383.5"^3 This is all using 1/2" mdf So after the sub dispacement and the volume the port takes up, the final volume of the box is 2.31 hertz and the port is tuned roughly to 31-33 hertz. By the way! the port will be facing the front of the cab!How do you guys think this will sound? 2001 Dodge Ram Kenwood Deck Pioneer speakers
