Hi
Right now I have 2 Kicker CVR 12's (2 OHM versions)
They are each wired individually to the amp, since the amp supports that (crappy quantum audio amp till I get my new one)
When I get my new amp (Sundown SAX-1200D or the Hifonics BRZ1200D), how should I wire them to get a final load of 2 ohms?
A resource for wiring diagrams or something would be great. Also, the sundown apparently supports "2 ohm linkable/dual mono" which I assume is the same thing that my current amp does, where it's a mono amp but you have two sets of terminals on the amp? Unless I'm completely misunderstanding what that is.
2005 Honda CR-V
AQ HDC315-A
Hifonics BRZ1700.1D .5 Ohm
4.4 ft^3 box
Kenwood Deck
Big 3
XS Power D5100R Starter, D975 Rear
Hi
2 ohm linkable means when you have 2 of the same amplifiers and you wire them together to get the most power from both. only reason monoblocks have 2 sets of speaker terminals is just to help make wiring easier. doesnt matter which + or - you use, it will work. and when you have, for example, 2 2 ohm woofers and you connect each one to a pair of speaker terminals on the amp, the amp will wire it down to 1 ohm since it parallels internally.
as for wiring to 2 ohms, here.
2002 ford focus hatch
pioneer DEH-P8400bh
infinity kappa 6.5 components front and rear
XS Power D1200
Shuriken BT-100
audioque 120.4
2 15 inch audioque HDC3 D2
2 audioque 2200d
big 3
mechman 220a alt with external regulator
479-418-3056
both the amps your considering are one ohm stable and thats where they put out max power, but with 2 Dual 2 ohm subs you can only wire to .5 ohm or 2 ohm
i DO NOT recommend wiring to .5 ohm
heres the wiring diagrams :drinks:
http://www.the12volt.com/caraudio/woofer_configurations.asp?Q=2&I=22
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Thanks for the info guys :)
Alright
And for my next subs I'm making sure to get dual 4 ohms so I can do 1 ohm as well. I bought these used and the price was right so oh well :P
2005 Honda CR-V
AQ HDC315-A
4.4 ft^3 box
Kenwood Deck
Big 3
  • Who's Online   0 Members, 0 Anonymous, 1592 Guests (See full list)
