I've talked to mechman on a 07 cadillac ext that had the voltage issues seperateing is the best way.I'm not sure the the 4pin oval is the right alt to use on the 07. Call mechman and ask.also look into ther adj harness to turn up voltage I know the yellow wire is sense wire to turn it on. You can't just hook it up to a 12v source. That's what I mean
i dont think using a 4 pin oval plug alt will be a problem, as it wont run anything in the truck.
the yellow wire i thought needed to be hooked up to a 12v ignition source, as in it turns on and off with the truck
if i can use the AVBM with the seperated alt then i will for sure.
just sold my AQ 18" so will be ordering my bracket this week
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
I have a dual alt bracket in my 03 Sierra, and have my alts separated also, I dont know where you are ordering your bracket from by i got mine from DC Power and it came with all the wiring and everything else you need to separate them.
You just take the wire that reads to voltage to your rear batt or the terminal on you t2500 and itll charge due to the power that it has there instead of the trucks alt and batt voltage.
Hope this helps
i will be getting the bracket from DC power also, hopefully it shouldnt be hard to install.
thanks for the info!
On my 98 the factory harness puts out like 6v not sure on the 07
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
so does anyone know what the single yellow wire off the alt is for? i heard that only one wire is needed to tell the alt to turn on, so im thinking i just wire that into a 12v ignition source
can anyone confirm this? the alt is a 300 amp iraggi alt
Found out from some iraggi users that I do only have to use the yellow wire, thanks guys.
my dual alt bracket will be here the 5th :)
  • Who's Online   0 Members, 0 Anonymous, 2635 Guests (See full list)
