Alright i will be ordering my dual alt bracket for my tahoe very soon, i will be running the stock 160 amo alt in the stock location, and a 300 amp iraggi alt in the bracket, running to one XS D3400, and powering a RF T2500BDCP, and a mids and high amp soon.
now one my alt, seen here
the 4 pin oval connector only has one wire, the yellow one.
what do i connect this to? a 12v ignition source?
this alt will be completly seperate from the stock electronics on the truck and will run only the system
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
You have to piggyback to your factory wire, just splice it. The way you isolate it is have that alternator charge your rear batterys only and hook all amps to that battery. Is this in the97?
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
/\ x2
why separate them?
and i believe thats the voltage sensing wire....is it self exciting or no? i believe you would run that wire to the 12+ side of the stereos battery (s).
hope this helps!
-jarrid
Edited by 95legwagon
i think there real i was looking through that guys stuff he sells and it looks like he finds stuff at auctions and just sells it
Yea, it looks like someone got the mids about a month ago....shit. If I had a whole Hertz front stage my ears would jizz all over my cheeks.
/ LOL
My Low Budget Build:
Green 1995 Subaru Legacy wagon 147k- $1K
headunit- pioneer premier deh-p650-$25
4 Lead acid batts. 1 up front and 3 in back- vented outside.- $50
4 vvme L11 10"s <- $30 shipped a piece
6 cu. ft box (after displacment) tuned to 32ish hz with 10 inch sonotube. -about $50 all together maybe a lil more
2 aspm 1300 strapped
Selenium 6"s in the front doors on headunit power- for now -$20
quantum tweets in door-for now -$10
boston acoustic 5 1/4 in rear doors- for now-Free
big 3
1/0 and 4awg throughout.
roof sound deadened (not peel n seal ftw)-free
on 80 amp alt (bench tested to put out 100 amps faithfully) <--?-$10 for test
about $430 for everything<----Not bad at all
still gotta add 3 way crossover, amp for front and rear door speakers and maybe eq
this is in the new tahoe
I have a dual alt bracket in my 03 Sierra, and have my alts separated also, I dont know where you are ordering your bracket from by i got mine from DC Power and it came with all the wiring and everything else you need to separate them.
You just take the wire that reads to voltage to your rear batt or the terminal on you t2500 and itll charge due to the power that it has there instead of the trucks alt and batt voltage.
Hope this helps
Contact us for the best quality cables and accessories with the fastest shipping in the industry
EMAIL: [email protected]<script data-cfhash='f9e31' type="text/javascript"> /* */</script>
LIKE US ON FB: https://www.facebook.com/SkyHighCarAudio
ADD ME ON FB: https://www.facebook.com/jon.rabe.1
MONSTER SKY HIGH/DC GMC: http://www.stevemeadedesigns.com/board/topic/127057-sky-high-monster-gmc-walk-through-12-lvl-5-15s-6-9ks-trim-panels-and-wiring-p-90/
I've talked to mechman on a 07 cadillac ext that had the voltage issues seperateing is the best way.I'm not sure the the 4pin oval is the right alt to use on the 07. Call mechman and ask.also look into ther adj harness to turn up voltage I know the yellow wire is sense wire to turn it on. You can't just hook it up to a 12v source. That's what I mean
Edited by dc98hoe
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 905 Guests (See full list)
