DD-1, a EQ, and a crossover help please
Well I found my Hu doesn't clip??? Followed istructions and the distortion light doesn't turn on even maxed to 35? If thats cool so be it. Now I also have a clarion eq after the HU going to a crossover then from there to a mono amp and a 4ch amp. My thimg is that the eq and crossover have there on level knobs and don't want to send distortion to the amps from any of these devices. What do I do? Everythimg seems very.straight forward this is my only hiccup. Thanks in advance.
Adjust the levels to your liking then tune the amps? If your not sure where you like it, try a referance point first and then check it. If you don't like it, play with the settings till its good.
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
One 18 AA Mayhem in a 4th order
ZED Levithian 6 channel
Rainbow Dual 6.5 comps ran Active
http://www.stevemeadedesigns.com/board/topic/155628-matt14s-yukon-mayhem-in-a-4th-ordernew-amps-and-bats/page-3
will wait for help :trippy:
Sorry guys for posting my ramblings its just that I want to get it to work.
I saved the tracks lossless to my zune as thats my main music source. Is this the problem? If it isn't really a problem is everything actually ok with the way the way gain can be turned up all the way but drtects no clipping in the 4ch????
my zuneHD uses the a headphone line from it to HU is that killing this?
Should I just use disk through HU even if I only use the zune????
:trippy:
:trippy:
Edited by crunkjuice1
well I'm hanging it up for today, most likely I'm missing something very easy I'm looking over but as of this second I have only radio straight to amps and I used the cd. Kind of bumbed because I only use my zuneHD and for the moment I don't have the supertweeters playing.
A MAJOR tidbit of advice is make sure the wire harness is seated down right or you might not get a good reading. Thats what i've learned so far. Hopefully someone will read my issues and slap me onto the right path.
What kind of amp are you running? A friend of line is running a alpine mono and a jl 4 channel . He has a high/low voltage switch on both and one clipped right away till we switched it and the other Diddnt clip at all. We then switched the m both and set the gains accordingly and was all good.
Edited by matt14
2006 GMC Yukon
Pioneer HU
SHCA ran throughout
Crescendo BC3500
were these supposed to come with 9v batteries? because mine didn't, and i don't stock these 9v, so now I gotta go buy one :( was hoping for $160 I didn't have to go buy a battery just to use it, oh well
2006 Mazda3 Hatchback Black 5 Spd Manual
Pioneer 4300DVD
2 Sundown SA-12 (34hz Tune, 3.22 cubes, 14.5 inches per cube, Triple Baffle)
Kicker 10ZX2500.1 (2845 RMS) Sub Amp
Kicker 11ZX650.4 (705 RMS) Mid Amp -- (3 Amps)
Kicker KQ3 Active Crossover
Kicker KQ30 Equalizer
Kicker 09QS60.2 Components (Woven Carbon Cones)
Kicker 09QS65.2 Components (Woven Carbon Cones) - (3 Sets)
2/0 Gauge Electron Beam Technologies (3 Runs, 2 +, 1 -)
1/0 Gauge KNU Kollasal Flex (1 Run for -)
300 Ft Kicker X-Series 16 Gauge Speaker Wire
XS Power D3400 (Rear)
XS Power D3100 (Front)
Singer Externally Regulated Alternator (Being Built)
+ The Love for Car Audio and BASS <3
UBL Build Log <------- Click Here-------> Normal Build Log (For Comments)
  • Who's Online   0 Members, 0 Anonymous, 1014 Guests (See full list)
