oknollenberg Posted October 9, 2011 Report Posted October 9, 2011 I have an all stock 2000 subaru forester and im planning on putting 2 alpine type R SWR-1243D 12" subs with 1800 watts and 600rms a piece with a kenwood 1000 watt amp with 600rms. My questio is should i upgrade the alternator on the car or will be able to get away with just keeping the stock one? also for the amp do i need 2 600watt rms kenwoods meaning 600 wat rms for both of the subs?
Andrew2944r Posted October 9, 2011 Report Posted October 9, 2011 Add a nice battery and test it out. If the voltage drop is to bad then I would look into upgrading. Team Ampere Audio
Guest Posted October 9, 2011 Report Posted October 9, 2011 no you dont need a new alternator. secondly, i recommend this amp over that POS kenwood http://www.audioque.com/AQ1200D-Amplifier_p_30.html thirdly, you should do the big 3 in 1/0 gauge so you dont put a shit ton of strain on that stock alt charging wire, and so you can charge at a higher voltage, and have less voltage drop.
oknollenberg Posted October 9, 2011 Author Report Posted October 9, 2011 no you dont need a new alternator. secondly, i recommend this amp over that POS kenwood http://www.audioque.com/AQ1200D-Amplifier_p_30.html thirdly, you should do the big 3 in 1/0 gauge so you dont put a shit ton of strain on that stock alt charging wire, and so you can charge at a higher voltage, and have less voltage drop. would i need two of those amps or just 1 im probs goin to hook up in parallel and they are dualvoice coils 4 ohm and so that will be .5 ohms for each
getlocivic Posted October 9, 2011 Report Posted October 9, 2011 ur running 2 dual 4 ohm woofers u can either do 8ohms per woofer thatd be 4 ohm mono load u can do 2 ohms per woofer for a 1 ohm mono load that aq1200d is PLENTY power for the hype rs. do the big 3 upgrade under the hood and get a 2nd battery in back and ur set do u know what the big 3 upgrade is??
oknollenberg Posted October 9, 2011 Author Report Posted October 9, 2011 ur running 2 dual 4 ohm woofers u can either do 8ohms per woofer thatd be 4 ohm mono load u can do 2 ohms per woofer for a 1 ohm mono load that aq1200d is PLENTY power for the hype rs. do the big 3 upgrade under the hood and get a 2nd battery in back and ur set do u know what the big 3 upgrade is?? no what is it and keep in mind this system will be transfered to a f150 once i find one so i want to be able to dismantal this so if if anything in this cant be taken apart once set up let me know cuz i dont want to f something up
oknollenberg Posted October 10, 2011 Author Report Posted October 10, 2011 Ok ive decided to do the Big 3 upgrade and install a kinetik HC 1800 battery with 2 alpine 12" SWR-1243d 1800 watt subs with an AQ1200D amp
Trey_Dog650 Posted October 10, 2011 Report Posted October 10, 2011 Ok ive decided to do the Big 3 upgrade and install a kinetik HC 1800 battery with 2 alpine 12" SWR-1243d 1800 watt subs with an AQ1200D amp Good stuff 13 Kia Forte Build! 07 Hyundai Accent Build ***Super Seller*** N8ball2013 And then he gets to say ok all you guys were right. im sorry for being a dummy poo poo head.
