the tittle says it all =D
right now the trim is a beigeish color (this is for a car)
would i use spray paint?
or house paint?
would i sand it?
some of the trim is metal/tin
and the rest of it is a plastic
please and thank you
-Egag
1994 Jeep Cherokee
!@#$%^&*(Soon to come)*&^%$#@!
TONS AND TONS of Audio Technix 80Mil
1 x 270 Amp Mechman Alt
1 x AQ3500D.1
1 x Rockford Fosgate T600-4
8 x Rockford Fosgate T2652-S
2 x XS Power D3100
1 x XS Power D3400
1 x eKs Kable 2 Channel Silver Plated RCA 5M
1 x Knukonceptz Kolossus Fleks Kable 1/0 Red 50FT.
1 x Knukonceptz Kolossus Fleks Kable 1/0 Black 50FT.
4 x Avenue - A605
2 x Fi Q 18
Scuff the panels with a red scotch bright pad thoroughly, then clean with wax and grease remover, then spray everything with a highbuild primer. After the,primer has cured, say 3-4 hours or just,wait over night, wet sand with 600 grit. After wet sanding clean with wax and grease again, and make sure you spray a sealer to prevent lifting. After you seal you wait about 20min and then go ahead and spray with whatever paint you choose.
Good Luck!!!!
Pioneer AVH480
Zapco ST5XII amplifier
Stevens Audio 6.5" components (passive)
Onyx Subwoofer
Sky High OFC wiring
