masterbusa2 Posted October 12, 2011 Report Posted October 12, 2011 Okay since I have been informed that a 4th order bandpass would produce the most spl for my car, i have started looking up what fs and all tht is and here is what I have come up with Power Acoustik Fubar 15" rms=1000 peak=1000 fs=27.2 vas= 4.5 Qms= 6.291 Qes= .496 Qts= .463 I used a random calculator I found xD S = .6 F3=25hz Sealed side will be 2.58 cu.ft Ported side 1.39 cu.ft LxWxH = Sealed (18.70,18.70,12.00) Ported (15.20,15.20,12.00) Tuning Frequency: 45.05 (Hz) Its saysing to make the port diameter 4.50 inches and 11.89 inches long, and I notice the Dimention of the two chambers are different therfore making it difficult to build for a ammature builder, if i put about a pound- pund and half of polyfill could i make the sealed side the same size as ported size or should i just raise the ported side?... this is what I have so far idk if these are accurate would like some light shone on this. thanks everyoen fro your input
D-train-13k Posted October 12, 2011 Report Posted October 12, 2011 why is your ported side so small. ? it should be closer to 4 cubic feet and your sealed side should come down closer to 2 cubic feet The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
fmedina Posted October 12, 2011 Report Posted October 12, 2011 ya i think youre suppose to use at least a 2:1 ratio. the 2 being the ported and the 1 being the sealed
D-train-13k Posted October 12, 2011 Report Posted October 12, 2011 as well i would do alot more port area closer to 17-20 per cubic foot of (ported side) The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
fmedina Posted October 12, 2011 Report Posted October 12, 2011 yo train my 4th order plan got changed :/ i got an OA15 lol just going to use an aero port enclosure to save some room in my trunk
D-train-13k Posted October 12, 2011 Report Posted October 12, 2011 yo train my 4th order plan got changed :/ i got an OA15 lol just going to use an aero port enclosure to save some room in my trunk ahh dang that sucks. should sound good either way though. The IrishmanCheck out my build hereXL 4th order wall build logIn Progress:alpine cda HU4th order Bandpass2xl 15's1- ab 400.1 (gonna be two hopefully)4- Crescendo 8's2- xts crecendo supertweeters 2 sq super tweetsMb quart 4.125Mechman 270a alt1- xs D27003- xs XP3000 4- odessey pc1700seller feed back threadhttp://www.stevemeadedesigns.com/board/topic/136418-d-train-13k/
masterbusa2 Posted October 12, 2011 Author Report Posted October 12, 2011 Well I can swap the stuf around making the ported side but 2.5 is as high as I can go on ported side and 1.4 on sealed, because my trunk is too small, what if I poly stugf
