i will be running one of the prototype DAT hellfire 1000.1 amps and i will be adding a 4 channel later in my 2000 jeep Cherokee. it has a stock 124 amp alternator. so about what size xs power battery should i get?
i also noticed they have "supplemental" batteries,what are those?
Edited by bass_stalker
JEEP BUILD PROJECT ANTIBLING.2000 jeep Cherokee.HEADUNITAlpine Cda-9886SUBSTAGE1 acendent 18" audio mayhem motor with a TI basket and tantric parts1 prototype DAT hellfire 1000.1HIGHSStockELECTRICALdb link 0 gaugeKnuconceptz Kolossus 4 gauge1 xs power d3400 under hoodBig 3 upgradeold fourwheeler build
The only way to delete your SMD account is for you crawl to steve meades door step on your knees and pleade for his forgiveness and acceptance to be released...He will either grant your wishes.....or choke you with a large piece of 0 gauge and electrocute you by hooking up a solid gold DC 12k at 0.000001 ohm and 10000 volts to your eye sockets and blow your head apart
You guys act like you have never clogged a toilet and ran around the bathroom frantically hoping it don't overflow.
ok back from work and school max dimensions are
Length11 Width7 Height 7.5inches
Go the 4xspower.com
with your dimensions and get the biggest batt you can fit under the hood
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
Pretty sure the supplimental batts are meant to be used as secondary batt, and not meant to be used under the hood
well i think a d3400 should be sufficient. all i should need are the 580sae posts.
now my other question is will this work with my battery pan since my stock battery is 11 x 7 x 7.5 and the d3400 is smaller at 10.24 x 6.75 x 7.2
ill do yellow top under hood and xs power in the back
CURRENT SYSTEM
(VEHICLE) 2005 JEEP GRAND CHEROKEE
(HEAD UNIT) KENWOOD KDC BT848U
(DASHBOARD) INFINITY KAPPA 32.9CF
(FRONT DOOR) JBL P693
(REAR DOOR) KENWOOD EXCELON KFC-X1730
(TWEETER) KICKER KS25 X 2
(SUB WOOFER) COMING SOON
(4 CHANNEL AMP) ROCKFORD FOSGATE T1000-4ADCP
(1 CHANNEL AMP) ROCKFORD FOSGATE T2500BDCP X 2
(PROCESSORS) AUDIOCONTROL DQXS & EPICENTER & MATRIX PLUS & DDC
(BATTERY) 1 OPTIMA YELLOW TOP
(SIGNAL WIRES) KICKER XI
(POWER CABLES) KICKER PKD1
(SPEAKER WIRE) KICKER 12 GAUGE
(INTERIOR) DYNAMAT
COMING SOON
2 FI SP4 18 COMING SOON
2 XS POWER XP3000 COMING SOON
DC POWER 270XP ALT COMING SOON
Yes it will work just fine,
Lol why? A single d3400 under the hood is more then enough for what he's running
lol i thought its better 2 batteries than i and to have extra juice lol
CURRENT SYSTEM
(INTERIOR) DYNAMAT
COMING SOON
more 0 gauge i will need lol
