CJs F150 6 15s & 10k+ UBL
Finally got around to making a UBL for my truck. Hope everyone enjoys.
Equipment list:
Subs- 6 DC Level 3 15s and 1 Level 3 10
Amps- 1 DC 7.5k, 1 DC 1.2k, 2 DC 175.4
Batteries- 1 XS d6500, 1 D3400, 1 D680, 5 XS d1400
Alternator- 1 Iraggi 260a and 1 Mike Singer 350a
Front Stage- 5 Sets AA Carbon Mids and 3 Sets Kicker SS tweeters.
Please Leave comments here:
http://www.stevemeadedesigns.com/board/topic/118463-cjs-06-f150-6-15s-and-20kw-1012-new-tl-and-pics-pg-19/
5 XS D1400s
XS Power 14v Intellicharger
Got lucky and the buss bars I built for my old 3400s will fit these perfectly.
50' each of 4ga and 100' each of 8ga Knu Konceptz wire
2 pieces of 18"x24"x1" Plexi
DC Level 3 10
DC 1.2k
Mike Singer 350a alt- This Bitch is HUGE!!!
Build has officially started. First on my list to do was to swap the dual alternator out for a new Mike Singer 350a unit.
Singer on the Left, Mechman 270 on the right
Installed
Mechman Adjustable voltage
2 runs of 2/0 Welding wire running to the back 14v batteries
Front D6500 running on the stock location iraggi 260.
Stinger sent me a nice message with my volt meter
If anyone knows how to make it tell me what the voltage is please do. Once it gets over 16.5 is just says HI.
Wall is starting to go up.
Old false floor and amp rack
Start of the new floor
Stripped the old dynamat
Second layer of back wall getting primed and painted
Goal for today was to get the Second layer of the back wall installed, build the floor and get one side built and installed.
Passenger side
Plexi Window
In the truck
Thats is for tonight. Tomorrow I will get the drivers side and top built and installed.
More done today.
Passenger side brackets installed and side mounted in truck.
Assembly of the driver side.
Outer piece is wrapped and inner piece is painted blue
2 1/2" sandwich pieces to go around the plexi.
Both sides now installed
Top installed
Bottom 45 started
That is all I have for now. The bottom 45 is drying and will be installed today. I may try and get the top side corners installed today as well.
The shell is 99% done.
I have 6 corners that do require so small glassing, 4 on the bottom 45 where I had to notch around the bolts and brackets and 2 on the top side corners. I will get that work done tomorrow and get the front baffle planned out. Kind of burnt out after 4 days of work on this thing so tomorrow will be a nice easy day. I should have the front baffles cut and installed on Sunday and have everything ready for the arrival of the subs and amps on Wednesday.
Todays project is glassing the corners and getting it all sealed up ready for the front baffle and bracing tomorrow.
Once the glass has dried, I will be adding some more on the outside in the top corners where you can see the gap in the last pic.
It will get sanded down today and the entire inside of the box will get one last coat of paint.
Todays progress included glassing the edges, adding a final coat of paint to the inside of the box, and building the buss bars for the 5 D1400s.
Tomorrow will be a big day. The port will get built and installed, inside of box will get resin, Front baffles will be built and installed. If I have any day light left I may try and get the front to back bracing built and installed also.
  • Who's Online   0 Members, 0 Anonymous, 2073 Guests (See full list)
