CJ18 Posted October 15, 2011 Author Report Posted October 15, 2011 I ran my SAZ-1500 @ .5 ohms daily for 2 years, not one problem. Just saying, either way I guess I might be the first to run @.5 daily on a 12k There is a HUGE difference in running a 1500w amp at .5 ohm and a 12000w amp at .5 ohm. It takes MUCH MUCH more electrical to support running that much power at .5ohm. As has been said here before, the 12k is a 2 channel amp. BUT it is .5 ohm stable per channel and 1 ohm stable bridged, so when looking at it bridged you can think of it as a normal mono block amp for wiring options. Daily I would wire it no lower than .7ohm bridged(.35 per board) Quote
AA98hoe Posted October 15, 2011 Report Posted October 15, 2011 That's what I'm goin to run mine at if I get it. .7 brigded or .35 stereo. ;-) Quote TEAM DC AUDIO VEHICLE:98 chevy tahoe 2wd 3-4 drop HEADUNIT:alpine 9886 PREAMP:arcaudio FRONT STAGE:4-6 1/2s selinium,DD component set and 4-selinium tweeters in each door KICKPANELS:jl audio 5 1/4 REAR DOORS: dd components 6 1/2s HIGHS AMPS:zapco 750.2 on front doors,zapco an another 750.2 on kicks and rear doors SUBS:4-ascendant audio 18s with 5 spiders in a custom box built by KINGSUV SUB AMP: 2-dc7.5s ALTERNATORS: 3-mechmans 1- 425comp, 1-smd spec350, 1-270 with adj voltage harness on custom dc bracket WIRE:10-runs 0g front to back BATTERIES:6-d1400s TL results:157.1 at 38hz and 156.8 at headrest score @37hz. STATE AND NATIONAL RECORD IN MECA S5.
extremeauto Posted October 15, 2011 Report Posted October 15, 2011 nice and thanks 4 posting ! Quote 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing!
