1sickpuppy Posted October 14, 2011 Report Posted October 14, 2011 One of my old stand-by amps that I have run in three different rides has completely died. It's been through a lot. I first tried to kill it by hooking up the negative to the positive and vice versa on the amp without taking the fuse out or disconnecting the battery, I have learned since then. Then a buddy of mine decided to drop his beer all over it while it was on, no more beverages around my stuff. And recently the high pass/low pass selector switch became inoperable so I had to put the amp on full range and use my HU as the crossover, I was using the amp for a pair of 4x6, I don't need sub 40 Hz. waves rushing through those little guys. and to top it all off the left channel was putting out very, very little out put so I had to run both left and right speakers off the right side. As you are probably wondering what amp I'm talking about it's a Hifonics XI series Isis, circa 2001-2002. A great little amp. Two ohm stable bridged 300 wrms. One ohm stable on each channel 50, 75, 100 wrms. My question to the public is what should I do with this warriors carcass? I was thinking gut it and mount it on the wall of my man cave? What do you think I should do with it? My Current Project: 2006 Ford Focus ST HU: Kenwood KDC-X986 Amps: Rockford Fosgate R300-4 Hifonics Brutus BXi 1601D Sub(s): (2) Skar VVX8 want to add 2x Mids/Highs: VXI65 components (front doors), RE Pro 5x7FR (rear doors) Wiring: Big 3 done in Candace 1/0 awg. 1 run from battery to distro-block 1/0 awg. Cadance wire 4 awg Stinger wire from distro-block to amps. Electrical: stock alt. Optima Red Top.
masterbusa2 Posted October 14, 2011 Report Posted October 14, 2011 Man cave gut top and plexi glass instead of top plate
Basshead89 Posted October 14, 2011 Report Posted October 14, 2011 send it to me for my collection. :-) Its a Zed Built amp so it might be repairable.
extremeauto Posted October 16, 2011 Report Posted October 16, 2011 use it for the man cave 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing!
iceman1575 Posted October 16, 2011 Report Posted October 16, 2011 Man cave, or have that one guy that Steve uses to rebuild his amps rebuild it back to new life? Just suggesting. POTATO!
1sickpuppy Posted October 18, 2011 Author Report Posted October 18, 2011 Thanks for the suggestions. I think I'll retire it and mount it on the wall. My Current Project: 2006 Ford Focus ST HU: Kenwood KDC-X986 Amps: Rockford Fosgate R300-4 Hifonics Brutus BXi 1601D Sub(s): (2) Skar VVX8 want to add 2x Mids/Highs: VXI65 components (front doors), RE Pro 5x7FR (rear doors) Wiring: Big 3 done in Candace 1/0 awg. 1 run from battery to distro-block 1/0 awg. Cadance wire 4 awg Stinger wire from distro-block to amps. Electrical: stock alt. Optima Red Top.
Purplehaze Posted October 18, 2011 Report Posted October 18, 2011 Thanks for the suggestions. I think I'll retire it and mount it on the wall. Yes, then you should buy mine! Kickin' Cruiser Seller Feedback Stage 3 Dash, Door Panels,4th Order wall 4 - 15'son a DC 5.0K 2 DC 5.0K'sSolo X 15 (v.2) Sub Build
Blackedout Posted October 18, 2011 Report Posted October 18, 2011 Take the cover off the back, snap picture, upload to imageshack, post pictures, and then mount it on the wall. Repairing it may be $80+ if it is possible to do so. If it's worth it to you, places like DB-R may be able to repair it. Trunk Build Log
