buckeyes#1 Posted October 15, 2011 Report Posted October 15, 2011 (edited) ok this is my 1st post so hello to all , ive been all over the net looking for this big 3 issue i got . well i have a 2007 hhr and the battery is located in the trunk the alternator is a stock alt. and there is 3 power wires running out of the alt one is running thru the outer fuse box one i dont where its going one back to the battery do i need to just replace the one ruuning back to the battery ? and if so we are talking 17 ft run should i run 2 inline fuses? just need to try to get this completed asap as im killing my car with electrical issues. running a kicker 1500.1 and a rockford 400.2 0 gauge power wire and a Kinetik KHC2400 battery and a stock 115 amp alt, i need the big 3 but please help with suggestions on a trunk mounted battery tia Edited October 15, 2011 by buckeyes#1 Quote
lem43606 Posted October 15, 2011 Report Posted October 15, 2011 ok this is my 1st post so hello to all , ive been all over the net looking for this big 3 issue i got . well i have a 2007 hhr and the battery is located in the trunk the alternator is a stock alt. and there is 3 power wires running out of the alt one is running thru the outer fuse box one i dont where its going one back to the battery do i need to just replace the one ruuning back to the battery ? and if so we are talking 17 ft run should i run 2 inline fuses? just need to try to get this completed asap as im killing my car with electrical issues. running a kicker 1500.1 and a rockford 400.2 0 gauge power wire and a Kinetik KHC2400 battery and a stock 115 amp alt, i need the big 3 but please help with suggestions on a trunk mounted battery tia yes the one that runs back to the battery, you dont NEED to fuse but a lot of people like to fuse that line. Quote 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
buckeyes#1 Posted October 15, 2011 Author Report Posted October 15, 2011 ok so 1 inline fuse is good just for protection then Quote
buckeyes#1 Posted October 15, 2011 Author Report Posted October 15, 2011 ok another question is my capacitor really needed some say yes others say no if no could i get a answer y Quote
lem43606 Posted October 15, 2011 Report Posted October 15, 2011 ok another question is my capacitor really needed some say yes others say no if no could i get a answer y no it isnt needed. if you have a bigger AGM battery and the big 3 done.. lose the capacitor.. the reason they are bad for your electrical system is they work off a push pull charging system meaning they charge up and drain in a matter of seconds which makes your alternator work even harder.. as the battery it charges in differnt cells holding the overall charge longer Quote 2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
buckeyes#1 Posted October 15, 2011 Author Report Posted October 15, 2011 ok thanks when i do the big 3 i will lose the cap then and try it out Quote
Sanitarium Posted October 15, 2011 Report Posted October 15, 2011 yes the one that runs back to the battery, you dont NEED to fuse but a lot of people like to fuse that line. Fuse between any potential power source and any potential ground out point. People who don't fuse that line are like people driving around without insurance >> tarded. Quote
extremeauto Posted October 15, 2011 Report Posted October 15, 2011 make sure u fuse all batts @ the positive connection,and the more grounds you have (strut towers,body,seat belt....etc ) are gonna help truthfully that 2400 should laugh @1500 watts grounds dont need to be fused tho Quote 1995 Honda passport 3.2 4x4 Frankenstein on a budget ballistics sound deader (roof only so far) kenwood mp3 usb audio control 3 (upgrading) hifonics mx-3 3 sets of massive px5 5.25s 3 sets of massive tweets phonix gold 5.25 componets x2 massive nx4 nano 200x4 mids sony xplod 600x4 watt high's 2 Fi bl fully loaded box walled @31ish hz 13.2 cube box/wall massive DB8000 Excessive amaperge 250 amp alt wir extrnl regulator daul runs of xs power xpflex 0 gauge big 3 raptor 0 gauge power/ground wire full run suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt scytek galaxy 2way alarm still upgradeing!
