Posted (edited)
ok this is my 1st post so hello to all , ive been all over the net looking for this big 3 issue i got . well i have a 2007 hhr and the battery is located in the trunk the alternator is a stock alt. and there is 3 power wires running out of the alt one is running thru the outer fuse box one i dont where its going one back to the battery do i need to just replace the one ruuning back to the battery ? and if so we are talking 17 ft run should i run 2 inline fuses? just need to try to get this completed asap as im killing my car with electrical issues. running a kicker 1500.1 and a rockford 400.2 0 gauge power wire and a Kinetik KHC2400 battery and a stock 115 amp alt, i need the big 3 but please help with suggestions on a trunk mounted battery tia
Edited by buckeyes#1
yes the one that runs back to the battery, you dont NEED to fuse but a lot of people like to fuse that line.
2 Fi BTL N2 18s Fully LoadedSundown Audio NS-1Kenwood 845 HU Clarion EQ4 Juicebox 3100sKnu Wire"Big 3"Mechman 270a156.3dBTeam GG.
ok another question is my capacitor really needed some say yes others say no if no could i get a answer y
no it isnt needed. if you have a bigger AGM battery and the big 3 done.. lose the capacitor.. the reason they are bad for your electrical system is they work off a push pull charging system meaning they charge up and drain in a matter of seconds which makes your alternator work even harder.. as the battery it charges in differnt cells holding the overall charge longer
Fuse between any potential power source and any potential ground out point. People who don't fuse that line are like people driving around without insurance >> tarded.
make sure u fuse all batts @ the positive connection,and the more grounds you have (strut towers,body,seat belt....etc ) are gonna help truthfully that 2400 should laugh @1500 watts grounds dont need to be fused tho
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
