AQ subs
boogie0410
I have just bought a cherokee,and I did a quick measurement,and I came up with this:18x42x25 o.d .What would be best?Two 15s,or one 18?AQ of course. LOL
Go with a single HDC3-18D2 ... you'll giggle like a schoolgirl every time you crank it up!
Headunit - Pioneer AVH-P4250 DVD
4 - infinity reference 6.5
a pair of infinity reference tweeters
1 - AudioQue AQ-120.4 amplifier for mids & highs
1 - AudioQue AQ-2200D Monoblock
1 - AudioQue HDC315
KitAudio kerf ported Enclosure
4 - Stinger pro series signal wires
20ft Stinger 1/0Ga power & Ground wires
Big Three Upgrade
1 - Kinetik HC1800 (Not Here yet . .Still Saving up for one)
2 SDC2.5 15s is what I'd shoot for, With the power and the room that you have. You're looking at ~3.5 cubes each after displacement, with 3 6" aeros. Double baffled and braced. Tuned at 37 to play any type of music you want. Sub up, port back.... 6-8" off the hatch.
If aeroports are out of the budget, A slot port would yield you 3.2 cubes after displacement each, double baffled, braced internally, which would work fine too.
If you wanted to run a single 18, I'd shoot for a box that looks something like this:
Reason being, 8 + cubes is a little much for an 18. I'm sure it would work, but if you're dead set on a single 18, shoot for a 4th order. It would probably make more sense.
thanks for the reply.I have not made up my mind,but I thought about a single hdc318 on a 1200d for a little while,and then another one when its broke in.
might as well get the 2200 if ur gonna get the hdc318 just set the gains low for the break in period then set the gains properly after the break in period and ull be more than happy
x2 get the 2200 the one HDC3 will love it. :drinks:
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 1257 Guests (See full list)
