i know this sub is limited as far as wiring it up goes but i think if its done right i can reach a 1 ohm load with these woofers
here is what the woofers look like
here is the jumper to switch between 4 ohm or 1 ohm
i may be wrong but from what i under stand if you series it doubles the ohm load and when you parallel it cuts ohm load in half.
correct me if im wrong.
so my idea is to series the subs together with a starting ohm load of 1 ohm per sub witch will then make it 2 ohm then parallel the subs into the amp to make it 1 ohm in the end here is my diagram to show you what i mean.
this is how i currently have them set up for a 2 ohm load
thanks for all the help
http://www.stevemead...f-system-build/
2001 VW GTI with a 1.8T motor
BIG 3
Pioneer AVH-4200DVD DOUBLE DIN HEAD UNIT 6 - 4 VOLT PREOUTS
RF T1500-BDCP (running at 2 ohm)
RF T400.4
RF T1 D212 x2 (in ported box)
RF 1/0 TO 4 GAUGE distribution block x 2
all stinger wires
200a alternator (SINGER ALT)
RF T2652-S (6.5 MID BASS AND 1" TWEETS in front and rear)
KINETIC HC 800 BATTERY (Front)
KINETIC HC 1200 BATTERY (BACK)
120ft of 1/0 stinger blue and clear matt
20ft of 4 gauge stinger blue and clear matt
30ft of 8 gauge stinger blue and clear matt
100ft of 12 gauge stinger speaker wire black
What amp are you running ?
2006 Dodge Charger
(2) Kinetic 3800
(1) DC Power 270XP
(4) T1-12D4
(1) T2500BDCP
(2) T400.4
7.5 cubic ft.
(2) 6 in ports thru the rear deck
(2) T165.2
(2) T169.3
rf t 1500.1 bdcp
Edited by 01VWGREENMACHINE
BIG 3
RF T400.4
all stinger wires
Bump
BIG 3
RF T400.4
all stinger wires
.5 ohm or 2 ohm are your options as the subs are D2.
If at first you do not succeed, you are doing it wrong! -ARS
Check out my walled TBSS build over here
4 Fi Team 18s on 2 Cactus K9
DS18 doors on 2 MBQ 1Ks, Vifa pillars on a STL4.500
Pioneer X8500
6 XS Power D7500, 1 3400S
Second Skin
2 270a Mechman Alts
