Speakers cut out but h.u works
Driving in to work today all 4 speakers up and quit working, only sound I had was the subs in the trunk. I had the music turned up kinda loud on the interstate and thought what I was hearing was distotion. Definitally wasn't that. After I turned it down all speakers just went dead. When I got to work I disconected the subs and wired up the rear speakers. No bass sucks, but at least I gots my music
Edit: so my question is do I buy a newget h.u or do I get an e.q and a second amp?
Edited by hershy314
Pull your HU make sure there aren't any bare wire or you antenna cable isn't unplug for some reason my antenna came unplugged and mine did the same thing. Also make your you have a good ground
lifted trucks gorgeous sluts a pretty face and slammin bass
My current Set up
Car less :(
I Do Ported Box designs/cutsheets with 3d google sketchup model just PM
i would really want an in-depth guide
Just flip the fucking thing over
Try resetting the hu if you hav'nt already, I say it's worth a try.
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
All 0/1 awg jl meta wire
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
Crunch gpv1100.2 (for 6.5"s only)
AQ pro audio 6.5" - 3 sets
AQ supertweeters - 2 sets
2000 Slamry
Their should be a little reset button somewhere on the faceplate or maybe behing it if it comes off. I would be able to tell you where maybe if you post up the model number. Can you run out and get the model number?
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
Most pioneers have the model printed on the face if there's a way to reset them id like to know to
My current Set up
Car less :(
They're usually behind the faceplate if the hu has a removeable faceplate. The reset button is just a tiny little button that the tip of an ink pen will barely fit in push it in and hold for a few seconds and it should "reset" the hu or restore all settings to factory. I've had a few hu's cut out the speakers running on it and the reset button made the fix, dont know why or how but it worked. :)
145.9@40hz
145.3@34hz
big 3
X2 group 34
Deka Group 31
Alpine CDA 7894
Orion HCCA D5000
2 AQ HDC312's
2000 Slamry
  • Who's Online   0 Members, 0 Anonymous, 1914 Guests (See full list)
