check on having it rebuilt im planning on doing that and the people giving me the name of the guy to have rebuild mine said they had theirs rebuilt for around 1000
2001 Dodge Ram
Kenwood Deck
Pioneer speakers
A used one is gonna be more than 1k,jasper has rebuilt ones that come with a 3 yr 100,000 mile warranty on parts and labor.but a brand new one will cost about 5k.
Member of Team 808
Member of Team North East Spl
I got mine from a wrecking yard for like 950 it was a factory crate motorthat came out of a wrecked tahoe with less than 50.000 on it. Runs excellant I've put 25.000 on it since feb lol
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
try http://car-part.com or carquest if you have 1 near you .....i looked on car-parts com but there pretty pricey in you area for a used engine if you want new your gonna heve to spend closer to $2500.00 there are some with less than 100k mile but there in my area and shipping would be high as F**K.. good luck hope this helps
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
ive been looking for a while now i was jus wondering if you guys knew of any! ive got my old motor, btw i have a 97 silverado 1500 with the 5.7 vortec.. i hate the intake on that stupid motor.. 4 blown intake gaskets! this time it was leaking water into my oil and i spun a main and rod bearing! soo.. i think im gonna rebuilt it myself i alredy pulled it out and broke it down thats how i know what happened.. and i think i can get a rebuilt kit for like $425 so.. yea i think im gonna rebuilt it!(:
hate to tell you but if you spun a main bearing get ready to go to the machine shop and have the block done take some pictures and post them up like to see the damage. i just rebuilt a 94 vortec 6 cylinder because of a bad main and rod bearing cost around 2500
i already know this lol i kinda thought you guys would expect that.. you know what your talking about! lol im getting the heads done, block redone and the cylinders honed.. so anyways it'll be practically brand new when im done
i make sooooo much money off GM intakes what is the main cause of this is the dex-cool coolant used by GM .it after time will turn very acidy and eat the plastic in the cooling system. the way to fix this issue permanently is to get the *fel pro gaskets* lower intake set that's is metal instead of the plastic (its referred to as the problem solver kit) then instead of using dex cool flush your cooling system with water till it comes out clean.(i use a garden hose& air hose to blow the heater core,rad,and heads out be careful not use to much pressure ) put it back togther run with water and clean oil dump oil and water.re fill with all makes all models anti-freeze and fresh oil with filter....i would do this on the new engine and never have a issue again...like i said i do ALOT of lower intakes on GM's & make sure to get all gasket areas lookin new b4 re Assembly ....good luck
Edited by extremeauto
kenwood mp3 usb
hifonics mx-3
13.2 cube box/wall
massive DB8000
big 3
still upgradeing!
