wiring two hcca-d2400 amps
mr151
So I have two orion hcca-d2400 amps and two hcca-12.4 subs. I need help figuring out what way to wire them. Would I be better wiring the subs at 2 ohms and run one sub per amp or wire the subs at 8 ohms and then wire both back to 4 ohms and strap the amps? I think his would put the amps back to 2 ohms. Does anybody know what would happen if I wired the subs to one ohms and strapped the amps? I know the amp isn't listed as being stable but I thought I would ask. Im trying to get the most watts I can any help would be great.
If you strap them at 4 ohm, or wire each sub up to its own amp at 2ohm, its gonna be the same power output from the amp. Cause each amp will see a 2ohm load either way
Run one amp per sub and gain match.
Thank you and come again
:ninja:
When your at the top everyone is coming for you, friends, family, haters and even those who don't know you.. my advice.. KILL EM ALL
  • Who's Online   0 Members, 0 Anonymous, 645 Guests (See full list)
