alpine 9886
I was testing rca output voltage and only got 2.4v with volume on 30 and sub volume maxed at 15.before it clipped with dd1 Isn't this deck suppose to be 4vout
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Mine goes to 35 unclipped if eq is flat
3.94v clean
On scope and dd1
Keep in mind the dd1 doesn't check just for clipping (if I remember correctly) so it could be tripped for just a tad bit of otherwise distortion. What were you using for a track?
40hz tone copyed to usb. I use usb to burp with and its dirty I know
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
3.94v clean
On scope and dd1
With cd or usb
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
You think if I recopy 40hz track from comp at higher rate it will be cleaner?
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
-5db track
Im clean with zero and -5db
But.
2.4 is plenty btw.
If your going into a preamp.
Thanks after Saturday dbdrag ill test an retune. If my pending amp sale goes through ill have a 12k to tune next week:-)
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
  • Who's Online   1 Member, 0 Anonymous, 1224 Guests (See full list)
