You nor your "mate" should be working on a car.
Take it to a pro before it gets worse
Sounds like an easy fix now as long as you know what your doing, which you clearly do not.
Thanks ray. But I actually found it myself. The wire had been pulled and got caught between a piece of plastic behind the dash. Fixed that up and it's all goods.... Like u said, easy fix
PSN: Rcp_soundz
Good rule of thump is go by what fuse size is being used in these amps. The higher the more amperage it pulls, this is what I look at.
I'll stick a 300 amp fuse in a potato and sell it to you for $2k.
1991 Mazda 323VERY small build thread here: http://www.stevemead...23-small-build/
Go kick your friend right in the balls.
Then facepalm yourself.
Then get back on track with your stereo
I think I deserve a kick aswel hah. Thanks for the help
PSN: Rcp_soundz
