update: here's where i'm at right now. i really wanted to do a flush mount. like reeealy bad. but not enough space to do it properly trying to figure out what the fuuuuuuuuuuu i'm gonna do for bracing.
i am goin to use fiber glass,threaded rod and 45s to brace mine up :good:
1995 Honda passport 3.2 4x4 Frankenstein on a budget
ballistics sound deader (roof only so far)
kenwood mp3 usb
audio control 3 (upgrading)
hifonics mx-3
3 sets of massive px5 5.25s
3 sets of massive tweets
phonix gold 5.25 componets
x2 massive nx4 nano 200x4 mids
sony xplod 600x4 watt high's
2 Fi bl fully loaded box walled @31ish hz
13.2 cube box/wall
massive DB8000
Excessive amaperge 250 amp alt wir extrnl regulator
daul runs of xs power xpflex 0 gauge
big 3
raptor 0 gauge power/ground wire full run
suriken 45 amp hour x3 shriken bt-120 batts,interstate 1100CA semi batt
scytek galaxy 2way alarm
still upgradeing!
Steel rods into support plates mounted inside the box?
more than likely with some big washers as well i posted my plans if get a chance check em out i am new to the box building scene tho...lol
kenwood mp3 usb
hifonics mx-3
13.2 cube box/wall
massive DB8000
big 3
still upgradeing!
looks good and very strong is that x3 layers of 3/4 wood?
kenwood mp3 usb
hifonics mx-3
13.2 cube box/wall
massive DB8000
big 3
still upgradeing!
yes sir. i also added some sonotube to direct airflow in the port. it's 4" radius, but could do 5" or more. i'd be interested to see what the size of the sonotube did to the numbers.
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
Update 2. box is coming along better than expected. since i didn't do thicker wood, i'm using some triangles in the corner to hold the walls together better. this might be overkill considering it will be covered eventually by the 3x3 45degree thingy in the corner.
what do you guys think is a 3x3 45 enough or should i go bigger?
More box builds
IT'S DONE!!! haha this turned out really nice. better than i expected. now if somebody actually made this, oooohhhh that would be amazing. this could actually be set on it's side and be a rear firing enclosure, provided there was enough space.
i'm gonna try JRocket's specs next and see if i can't pull off something with the port in the middle. maybe end up with a big enough port to do what this guy did :D
anyways on with the pics:
again, if you like my work, please check out my facebook page and tell a friend!
much appreciated all!
-Jesse
Edited by 412 CVX
More box builds
Looks good id lose the verticle 45s and use a horizontal one on bottom across from port. Just my opinion. Mite hit you up for a design for my 4 18s and see what you come up with
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 3304 Guests (See full list)
