box looks ok, but Im hating the port..
the port should be the width of the entire box (and not as tall), using 3 common wall
Or it should be made the entire height of the box and use 2 common walls
Putting the port right in the middle causes lots of dead air space and usually hurts numbers.
thanks for the input. i'll keep that in mind next time. only reason i did it is because i swear i've seen meade do it before in one of his projects
Just say no to Ground Pounder Customs.
More box builds
some cars do over 170db with one sub, so clearly my two 12"s can do that in my car, with my knowledge too! look out bitches!
I'm with captain stupid.
okay turned out better than i thought! i had to double check myself because the numbers looked too perfect, but i guess take what you can get.
worked out to use most of 3 sheets.
[4] 38x32 (red)
[2] 27.75x32 (green)
[2] 27.75x38 (light blue)
[1] 25.5x19 (dark blue)
[1] 25.5x2 (yellow)
[2] 10.75x27.75 with a 19.75x2 rectangle cut out of one corner(this is the L shaped piece) (pink)
[4] 1.5 inch diameter dowels
Edited by 412 CVX
More box builds
I would split up the red panels due to blade thickness.
was thinking the same thing, so maybe 4 sheets just to be safe.
More box builds
  • Who's Online   0 Members, 0 Anonymous, 3304 Guests (See full list)
