loganberry Posted October 23, 2011 Report Posted October 23, 2011 Anyone semi local to me that can fix amps? I got 2 decent amps worth fixing. The first is a smaller power alpine 500-600 watt I believe but I love that amp, turns on fuses are good no protection light just no output...my drunk cousin spilt water on it after a concert I think and just went down the shutter sence. Second is a Kenwood amp and works 100% fine to my knowledge except I pushed too hard and broke off the copper plate for the 12v side so I assume you would have to open the whole thing up and replace the whole piece or whatever but last time I used it, it worked fine. Now Is there a reputable member on here that won't charge me more than the amp is worth to fix it like Joe. 00sdime00 but he's out on work I think. If you think you can do it reply and we will start talking I guess you don't really need to.be local cause they fit in flat rate boxes I just want someone who knows what there doing and is cheap. Thanks logan My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
loganberry Posted October 25, 2011 Author Report Posted October 25, 2011 Bump My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
loganberry Posted October 30, 2011 Author Report Posted October 30, 2011 no one can fix amps?? i dont wanna sent it to db-r or something cause i will be charged more than their worth. The kenwood i know for a fact is just a simple fix cause i know it still works just needs the copper extended back out and the alpine has some toasted mosfets i think im not sure though i havnt even opened it up to see. It still turns on though just has no output My F-150 Build GET ON THE BANDWAGON what if they tried messing with the amps when the subs werent louder hahah jk
