fusing amp
rear battery next to the amp. how far apart for the fuse. rear batt positive ------fuse 250------- amp. my question is how far apart for the dotted lines of wire.how many inches of wire where the dotted lines are at. i hope it makes sense.
I'd say max 18inches, but I'd try to stay closer to 12inches
so your saying like 6 inches from each side of the fuse? like this positive rear batt 6">----fuse>-----6"amp
18inches from the second battery, so start at the second battery count out 18 inches give or take I'd try to go a little less..... Cut wire install fuse holder ...... run the rest of the wire to the amp.
im talking about the fuse in this diagram with the second battery diagram pic. from the amazing amp to the ---- fuse then to the ---- positive of the battery. how long should those two wire be that go to the fuse.
edit: forgot diagram link: http://www.stevemeadedesigns.com/board/topic/98509-how-to-properly-fuse-amps-and-rear-batteries/
All the fuses in that diagram are 12inch away from the batt. Thats the correct way to wire the batts. Like I said I'd try to make em 12inches or less, but if ones 18inches it's not the end of the world.
ok thanx a lot!
Say all fuses are 12inch away from the batts. First batt fuse 12 inches away...... run the wire.....fuse 12inch away from second batt... I then fuse 12in from the second batt to the amp.
  • Who's Online   0 Members, 0 Anonymous, 1476 Guests (See full list)
