Use Seperate Batteries For each alt?
I just put on a second alternator in my mazda and I am curious on the best way to run it. I have 2 alternators, the factory battery and 2 batts in the cargo area.
I currently have both alts hooked to the factory battery and 2 runs of 0 gauge going to the back batteries on a bus bar. Is there a better more efficient way to do this?
are your two runs off the stock battery?
is your stock battery a wetcell?
2014 Chevy Silverado Crewcab
1994 Chevy Full Size blazer
What amp alts? Id do at least 2 runs from each alt to front batterys. Then more runs to back if you can afford it. How many watts
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
  • Who's Online   0 Members, 0 Anonymous, 1721 Guests (See full list)
