Hello to all from the great north. He my build which started as ss 1-2 then over to 3-4. Any questions let me know.
4 fi Btls
2 american bass 500.1
Built with single sheets of 3/4 and 2x6 and 2x4. lots of PL. Up to here was all for ss-1-2 Lasted a year got bored.
2009 SS 1-2 Canadian champ - 154.80
2010 SS 1-2 156.41 @ 62hz
2011 SS 3-4 156.5 @ 37hz Current Canadian East Champ.
Check out my vids
4 FI BTL SPL Dual Stack .7D
Numbers? And what do you hope to gain going to ss 3-4
TEAM DC AUDIO
HEADUNIT:alpine 9886
PREAMP:arcaudio
KICKPANELS:jl audio 5 1/4
SUB AMP: 2-dc7.5s
WIRE:10-runs 0g front to back
BATTERIES:6-d1400s
Round2.
Back of the was not too strong so rebuilt it with my buddy.
Check out my vids
Round 3.
Started to strengthen the rest of the box. added another layer of 3/4 to top bottom and sides. Back was ok being at 5" thick.
sucks has not having any space.
33.5 x 25" port .. sexy lows.
inexpensive bracing which works.
never glued it down the baffles. tuck taped them just for fitting in case i wanted to cut the port down a little or make other changes inside.
Check out my vids
At first my port was 33.5 x 25" and 10" wide. was hitting 154 @ 29hz. It was fun but didnt hit the notes i liked.
I have now cut down the port to 15'long and now sitting at 37hz @ 156.5. I will have lots of work to get this baby ready.
Last power test i was sitting at a starting rise of .3 up to 1.1 and 7300rms of power clamped.
Currently working on getting batts and new alt. Not charging above 13.4 not good.
Most important thing i forgot. The box is 34.6cubes and 95% square.
Hope you guys like it.
im on the left.
Check out my vids
Nice score if your going for straight spl id tune higher add more power and mod inside of box for better airflow. If you want to groundpound leave it
TEAM DC AUDIO
PREAMP:arcaudio
SUB AMP: 2-dc7.5s
BATTERIES:6-d1400s
for now im gonna leave it and do a few mods inside. this is a daily ride. Goals a 158 daily.
Check out my vids
Very nice build dude, i´ve seen all of your builds actually, i was considering building a flat wall just like that in my EX, but, i DD´s doesn´t like "small" ports at all, you managed to get around 335SQ of port with the flat wall, honestly speaking, that doesn´t work for my 3518´s (unless i´m doing something wrong haha) , that´s why i´m going with a 6th order in the future i guess, what´s the shell dimensions ?if you don´t mind me asking
not too sure my box sits between the wheel wells. indside is 42.5x33.5x45
Check out my vids
  • Who's Online   0 Members, 0 Anonymous, 833 Guests (See full list)
