Smaller C&D batts, GREAT prices!
IF INTERESTED, PLEASE EMAIL AT [email protected] AS I TEND TO NOT CHECK MY FOR SALE THREADS VERY OFTEN.
Item(s) for Sale:
20x C&D UPS12-100MR
Item(s) Description/Condition:
http://www.cdstandbypower.com/product/battery/vrla/pdf/12_100.pdf
Don't pay $80-100 for a used HC600 or Batcap 800, or even more for a XS D680...get more power reserve, and for less $$!
Just under 3 years old
21lbs
26ah rating, 400CCA rating via my CCA tester
6.54" long x 5.14" wide x 6.86" to top of tabs
Totally sealed and non-spillable AGM technology
40% more weight and higher ah rating than a Kinetik HC600 or XS D680
Resting voltage is between 12.65-12.75V, but I have not had a full charge on them just yet.
All load test just like they're supposed to.
This will make a great secondary battery for mid size systems that need a little extra reserve power for when the alt just can't quite keep up.
Price:
$60 shipped each, email me at [email protected] for quotes on multiples
Shipping and Miscellaneous Item Information:
Included
Item Pictures:
Ryan Miskin - owner of RAM Designs
I have my PM's turned off, please email at <script data-cfhash='f9e31' type="text/javascript"> /* */</script>
2200+ designs since March 2011...
I'll take two.. email coming.
90 Nissan 240sx
Avic z-140bh
Audison SR4
Audison Voce 6.5s
CDT es-20 tweeters
Sundown 1500v3
(2) DD 9510's
3 cube box 2 6" aeros
XS Power D2400 & Xp950
Skyhigh/Knukonceptz/Rockford Fosgate wiring
More Coming Soon.. Check my builds below.
97 Civic Hatch Build
86 Caprice Build
you can pick up a chick in a car... I think it'd be hard to roll up mackin on a broad sittin on a sundown. My opinion
Any of these have round post instead of the square 1s like in the pix
stevemeadedesigns.com/board/topic/105505-silvia-first-time-build-kenwood/
I do have one 150MR battery that has threaded inserts(like a normal big batt) instead of the tabs like these...but all of the 100MR's look just like the picture posted.
The 150MR(35ah rating) has stats similar to a Kinetik HC800 or XS D975...I'll let that one go for $80 shipped.
How many would you suggust for7k lol
Legal TL scores145.6 on the dash sealed up in the low 40hz area with the port out145.5 on the dash sealed up @30hz with the port inless then 1k clamped on a 3.5k!
Why would you EVER WANT flex?
huh?...flex is what can make the lows lower and more air being pushed correct?
me_zps0fb5a5b4.jpgMy FeedbackJeep-BuildlogPT LOSER buildlog
I have some Batcap 2000 clones made by DataSafe that will probably work better for that application(less batts, easier to wire with threaded insert terminals).
What size alt are you using, do you have the big3 done, and have you upgraded your stock battery?
Cuz I have 2 jl top post inlets that I'd like to still use
And the square post I don't want to use metel wedges to fill the gaps
If u have 1 that can reuse this then ill get 1
Actually, I have some Batcap 2000 lookalikes that I'm about to post for sale. $105 shipped for one of those, and it has threaded inserts(not sure if the JL things you have will fit though).
