2nd battery needed but not sure which one of these will work
Im finishing a build for one of my friends. He has two 12 dual 4 ohm Kicker cvr's on a Groundpounder gpv 2000.1 amp.He has a 2010 Expedition. At idle his voltage sit at about 14.8 to 15 volts. When we hook one speaker up by itself and turn the music up the voltage drops to about 13.8-14.4 volts at a 2 ohm load. But when we hook up both speakers to give it a 1 ohm load on the amp and turn the music up the voltage takes a wicked dive and barely drives the subs. Im wondering would a Kinetik hc800 be enough to keep the voltage stable or would we need a Kinetik kc1200?
2 woofers at dual 4ohms can only be wired at 1 ohm or 4 ohm load. Take a volt meter and check your load.
Is the big three done?
are the grounds good?
And if everything is I would go with a Kinetik 2400
Clip city bitch, clip clip city bitch. 10's, 12's, 15's, goin up in flames bitch.
TaylorFade, on 02 Jul 2013 - 9:38 PM, said:
Go back to that place, ask to speak to that dude again, look him dead in the eye and then.... pop him in the snot box.
Tell him T-Fade sent you.
the subs are at 1 ohm and the amp is rated t 1000 rms at 1 ohm. no big 3 and grounds are good
Do the big 3 that should help.
2 polk audio 4x6'skenwood head-unit 220 amp Mechman alt1979 Corvette
2003 corvette z06
alpine radio and the bose system that came stock
The big 3 will indeed a make a huge difference. Just changing the battery under the hood can also make a difference.
Big 3, upgrade battery under hood and do you have at least a good 4 gauge amp wire for the amp and same size ground?
VM-1
Pioneer DEH-80PRS
Hertz HSK 165XL
Arc Audio KS 300.2
Linear Power 1002 Full Mods
Fi Audio Q 10s
Sundown Audio Scv 3000
Big 3
XS Power D5100 Juice Box 20AH
Singer Alternator
Sky High Wire
<p>My Ebay feedback. http://feedback.ebay...tab=AllFeedback
[/quote/]
he has a 4 gauge amp kit.he is also running a Jensen 400 watt 4 channel amp as well
  • Who's Online   0 Members, 0 Anonymous, 1973 Guests (See full list)
