well let us know when everything star moving again
its not on complete hold, just missing some stuff to really get it fully going (alt, front stage). Ill be starting my amp rack tomorrow weather permitting.
Tuned in. Nice 4runner. Mines 6" lifted on 35's. I have two 15xl as well. Hope you will like 'em. Best subs I ever had.
'91 Honda crx - TOTALLED
200amps rebuilt Iraggi alt
2 d3100
Mojo [email protected]
2 15's DC XLm1 in 7.2cubes, 2 6" aeroports tuned to 32hz
SO this weekend i got some stuff done, changed the spark plugs, runs so much better now. Built the base framing for my battery box/amp rack and cut the sides out. Nothing is put together yet because we still have to mount the frame. Its supposed to turn out similar to like a trapezoid sub box turned on its face. Its pretty big because it has to fit the battery inside along with all the wires and be strong enough to hold 2 150+ lb batteries when I get the 2nd one. Planning to have everything hidden inside that rack/battery box. Also I may try to make something that resembles end caps for the 5.0k
So a small update, I decided to go active using 4 selenium 6w4p 6 1/2 speakers and 2 sets of massive ct1 tweeters. Planning on glassing the doors. Also will be getting 2 MB quart amps, the ONX4.125 (bridged 4ohm for the seleniums) and the ONX4.80(for the tweeters). Any suggestions on crossovers? I'm currently looking at the stetsom crossovers. Hopefully this weekend I will have the amp rack done, weather providing
This weekend I didn't do much because of weather, but I got the battery box/amp rack mounted, I gotta pick up some 1/4 mdf so we can do a layer of it all around the box for cover up because some parts aren't exactly straight. Ran some 3/0 welding cable. SMD DD-1 came in, along with 2 sets of CT-1 tweeters. Also started deadening rear doors. Gotta figure out how I want to convert the 5.25 speakers to 6.5, probably will make a mdf frame to mount on the factory location and put a 6.5 ring over it.
